Good evening.
My mum alerted me to her Panda this evening that it had started to overheat, I went out and took a look at the car, I started the car and left it to idle and the temperature creeps up very quickly, however there is no heat from the vents, the rad and pipework are cold, however the engine is HOT and I mean hot.
All of the above to me would suggest the waterpump has failed. The car is a 2004, 1.1 panda active with around 77k on the clock.
Thanks.
Thanks.
