Should do -- but remember, you're not after the blue one, but t'other one.
100% there is a fuel pump relay. It is the relay the guide for fitting a rev-counter points to...Check the wiring diagram -- but I don't think there is a fuel injector relay or even a fuel pump relay in the 899.
also thinking that there could be a fault with the ecu, if so, what's involved in replacing it?
