Stilo New Stilo Abarth owner
Hi I'm new to forum.I just purchased a 02 plate yellow stilo abarth has no tax or m.o.t bought as none runner got it home jump started fine runs perfect.only problem I have is airbag warning.and engine lights on so may need help during process of fixing it up for a m.o.t also my partner has a grande punto 57 plate 1.4 tjet so I wanted to join for advice and chat maybe a will come to some of club meeting s once car is sorted. Also my first fiat love the car really good condition 89000 miles some history with it. Must be top spec as has leather sat nav phone.5 CD changer.AC climate control.cruise control and a panoramic sunroof reverse parking sensor.basically everything lol.hopefully have it on road end of April going to service engine change all fluids and clean brakes.then get airbag warning off and eml off and send for m.o.t
I can update put new battery on today scanned engine codes transmission low voltage cleared them now new battery is on and never came back so happy. But can't clear airbag warning and its doing my nut in read on net something to do with glovebox there's a flap you pull down split yellow plug and clean with connection cleaner so I'll give that ago during the week fingers crossed. Thank Russ
Hi when my airbag light comes on I push
All the wires back into connectors under
The passengers seat!! And it goes away!!
Could try that!!!
Have a look at the orange connectors under the front seats. Lots of info about them. Usually these are the cause of most airbag stuff. Lots of people clean them with switch cleaner but it comes back after a while but i cut mine out and soldered the wires back together. Never had a problem since and that was 8 years ago.
Cheers guys lights now out. Going to modify using round bullet connectors as keep damp and crap out with rubber sleeves.
As autodata is showing a common problem and to buy modified blocks from fiat.rather modify it myself I would solder but be easier using bullet connectors incase i need seats out for any reason
