Ducato Purchased a 2007 ducato
dynacam
Member
Just purchased a 2007 ducato which as a motorhome in New Zealand and I am impressed with it
Would like to get hold of the service manuals for this model, any ideas where to find them.
244 ducato or x250 ducato 2007 was the overlap year as a lot of motorhome manufatures still had older stock.
It says 120 Multijet on vehicle, not sure where to find other number, is this any help ??
the VIN plate,
normally under bonnet,:idea:
should have body type code, along with engine type, and actual chassis number,
you will probably get quicker Ducato answers posting in the Ducato section, ;)
Charlie
Thats x250 you can download the service manual from the download dsection on the ducato forum, look for x250 elearn its a cd image in multiple parts and you need windows to run it.
https://www.fiatforum.com/downloads.php?do=cat&id=23
Things to look out for are the water feature see here or just googlw for ducato water ingress, ducato scuttle, ducato water feature:
https://www.fiatforum.com/ducato/27...ucato-water-ingress-unsealed-engine-rust.html
and clutch judder again just google.
Thank-you for the info
