Hej alle.
Kan nogen fortælle mig om fiat panda årgang 2007 er udstyret med canbus, da jeg overvejer at montere zenon lygter foran????
hi,
LED bulbs will probably require a resistor in Circuit to compensate,
AFAIK the H4 headlights are not controlled by the bodycomputer via CAN. (You get no message on the display if either of them is broken)
So Xenon should not be a problem as long as the law doesn't require washers and automatic dipping.
gr J
I think that what you over in the UK call HID's are called "Xenon" in Holland. Cars younger than '06 (I think) need the bits and bobs to get MOT (APK).
Normal shape H4 filled with Xenon instead of the normal gas are no problem overhere as well.
Since TS comes from Denmark I thought I;d make the info as complete as possible.
gr J
