Jstilo
Hi everyone,
i bought a fiat stilo 1.6, 2002 around six months ago. it has done only 35k miles.it was running fine during the summer. i around 40k now.
About 2 months ago.. the morning was wet and cold, i started the car..it started up in the first go itself...put it into gear as i started to move... it began to jerk... and my car shut down... tried agin the same thing.. after a few tries i started it up.. but the engine management light was on. so i went to near by garage and got it diagnosed. They said the MAP sensor was faulty and need replacement. i did that and it cost me £200. The very next day the same thing happened. i took it to the same garage. they checked it and said they could int find any fault with it.. so they cleared the engine management light and gave the car back. the car was fine for a few week...
then the engine management light came on again... this time i took to a frnds place... it did a diagnostics and found that it was the MAP sensor again.. HE said to leave it alone and cleared the engine management light. the car was fine was a week...
i was away that week end. that was a very cold week end. i started up the car car the following monday it wouldn't start. i got a frnd to jump start it for me... and it ran fine that week.. i tested the battery using a volt meter and it showed 12.5 and 14.5 when running. During the weekend i had a long drive .. the car didn't show any trouble... on Monday i drove to work in the morning... but in the evening.. i started the car..put in gear and as i moved forward the car shutdown.. i started it up again.. and drove off.. as i started to pick up speed... the engine management light came on... and the beeping sound also... i was not getting much power also.. but i got home...
i booked an appointment with fiat...they diagnosed it and is say its the coil in the 2nd cylinder... i am get it changed and its again costing me £230.... i am really sceptical weather this will fix the problem... i have spent a lot of money on this car till now and still is not reliable. more than the money its the hassle its creating... I am missing appointments and unable to get to my destinations.
Anyone having the same problem...
Any one have any advice....?? Any help is appreciated...
