kincaid1994
- Oct 23, 2013
- 2
- 1
Hi my name is marc im only 19 years old and have recently got myself a very nice ice green metallic 1.6 active sport stilo with only 54k on the clocks, when I got the car it wouldn't start as the previous owner had used dirty fuel then left it sitting for over a year so I started by draining the complete fuel system and installing a second hand fuel pump then I refilled with £20 of bp ultimate and £20 regular unleaded and gave the plugs a clean and adjusted the gaps and finally that got her running (just) I then realised that the alternator was shot so ordered a second hand one of ebay which works fine and replaced the battery now she runs but a bit lumpy which I hope that a good service and possibly a new fuel rail will sort if redex doesn't, anyway the problem now is that when running I have no power steering my airbag light comes on also a loose connection warning and after a little while It says engine fault aswell ? its really confusing as I really cant understand the problem as it was a family member who owned it before me and I know for a fact there wasn't any of these problems before it got parked up so its left me thinking that a earth point could possibly have been corroded and causing problems as the only other thing I could think of if the ecu being fryed but it was fine when parked up so ive ruled that problem out of the equation although I may be wrong hopefully someone here can help me
All comments and suggestions welcome and will be greatly appreciated as this is my first car to learn in so im itching to get it going right
Thanks Marc
Thanks Marc
