Lamps by Post - For all your lighting needs
Thread Tools
Old 05-08-2013   #1
No power
Help!!! My 52 plate stilo abarth has got no power when setting of in the low gears until around 3500 revs. It has only just started to do this. Was hoping for some ideas or advice to what might be causing this problem. Many thanks and hope to get some advise soon as its driving me crazy
Andrewbryn is offline Reply With Quote Quote
Old 05-08-2013   #2
Clivvy has donated!
Re: No power
Mass Air Flow sensor?
Clivvy is offline Reply With Quote Quote
Old 05-08-2013   #3
Re: No power
Are they prone to just going and is a cheap and easy fix or is it a trip to the garage. Cheers for the reply
Old 05-08-2013   #4
Clivvy has donated!
Re: No power
yeah sure, all MAFS fail at some point, you may not even notice the decline in power over time because its so slight.
easy check - unplug it - if the car drives the same as with it plugged in, then its likely to be your MAF although I would expect the EML to come on but it might be a stored code or the Abarth doesn't generate a warning (I don't know much about the Abarth).
You don't need a garage for this, the MAF is attached to the air intake before the engine, you can see it sticking out the top with a plug going in the top. Unplug that and try drive it. If its WORSE, then tis probably NOT your MAF.
Old 05-08-2013   #5
Re: No power
Thank you will try that when I finish work later and fingers crossed it ain't anything more untoward. Thanks for your advise
Old 05-08-2013   #6
Grumpy Old Manx Git
Peat's Avatar
Peat has donated!
Re: No power
Also you may want to check the EGR.
Peat is offline Reply With Quote Quote
Old 05-08-2013   #7
Re: No power
Sorry but what is the EGR?
Old 05-08-2013   #8
Clivvy has donated!
Re: No power
Exhaust Gas recirculation, a system that puts exhaust gasses back into the engine. Worth checking and blanking, if the Abarth has one...?
Old 05-08-2013   #9
Grumpy Old Manx Git
Peat's Avatar
Peat has donated!
Re: No power
Sorry.
Got finger up bum and brain out of gear. Skipped half of first post!
Thread Tools
(T) No power below 2500rpm help, power back above 2500rmp midayt47 Multipla 8 12-07-2010 12:25
(T) no power Garrison Ducato 7 10-01-2010 16:22
(G) No Power - Loads of Power - Great Instructorcon Ulysse 13 30-07-2009 08:21
(T) Power Steering/Power Assisted Steering Buffy Cinquecento / Seicento 5 30-03-2007 14:01
(T) Need more power it03f28 Punto (Mk2/2b) 2 18-03-2004 07:25
