Unless the car is fully loaded the front is usually a few psi more than the rear.
The same size tyres by different manufacturers use different grades of rubber resulting in different amounts of stiffness, they therefore require different pressures for optimum performance.
The handbook is a good guide, to be accurate its best to check with the tyre manufacturer.
