les1466
Member
Hi, I recently posted a thread asking for help with this problem but am still getting no further.
I have a 65 plate Punto Grande 1.4 dualogic semi auto. The car has only done 21,000 miles.
Approx 3 weeks ago I started noticing a red oil indicator symbol in my speedo clock then a warning on the LCD display saying "Transmission - please check handbook". With this the car had a judder when changing from 1-2nd gear and when the car was in reverse. What seems really odd is that this only seems to happen when the car has warmed up, it seems fine when running from cold???
I thought this may of been the gearbox oil needed changing so I took it to my local garage to get this changed. The oil was fine but I replaced it anyway. The problem still occurred. I took it back to the garage and as a favour they stuck it on a diagnostics machine. This come up with a fault code "P17444 Hydraulic circuit pressure sensor". The mechanic said that it might not be that as Fiats are notorious for having parts called something completely different. He could not find a part called that and no-one seemed to know what it was. He cleared the error code and said that this might clear the fault.
The fault still occurred so I decided to try and take it to a Fiat garage after much discussion on here and getting no where, asking every mechanic going and them not having a clue, or seemed to not want to know.
Unfortunately the Fiat garage could not get me booked in until after Christmas... AAAAAArrrrgghhhhhhh!!
So, a friend of mine said she has a fantastic mechanic. I rang him and went down to get his opinion. Immediately he said it was clutch judder, although he could not understand why it only does it in 1-2nd gear and reversing and only does it when the car is warm. I booked in for an hour with him so he could try to get to the bottom of the problem. He stuck the car on a diagnostics machine... The car now shown no errors. He took the cover off the selespeed to reveal the selespeed fluid oil bottle. This was slightly low, approx 10mm under the lowest level mark. Unfortunately I could not get any fluid that day so ordered some. I was praying that something this simple would be causing this problem.... It didnt. The mechanic after looking at the gearbox said he didnt want to touch it, it looked an absolute nightmare!!
So, here I am with seemingly no one in the world, or at Manchester, that has a clue what is causing this.
When the cover was off the selespeed I did notice what looks to be a very small black pump which looked slightly wet with the selespeed oil,maybe this could be something to do with this????
I genuinely dont think that this is anything serious as the car runs perfectly after it goes into 2nd gear and as I have said only happens when the car has warmed up.
My main concern is getting ripped off for something that might be nothing. I dont mind paying but obviously I dont want someone taking the mick!!
Can anyone or a good Fiat mechanic advise me or may know what this is? I really need help with it.
Any help to get to the bottom of this would be very welcome.
Les
Les
