hi all new to the forum so be gentle
sorry if this is a bit long winded but i will explain best i can
ok friends 06 punto had engine check light on so plugged in my code reader after problems connecting messing with fuses i find the lighter fuse blown i swap this with window one and cleaning sensor contacts i see on dash coolant temp warning although engine not overheating so i think temp sensor . plugged code reader in again and now connects and pulls the following codes p0115 engine coolant temp circuit p0615 starter relay circuit and u0001 i clear codes but they keep coming back. i look at live data and its not showing as running hot. then it wont start as if there's not enough power in the battery just starter solenoid clicking so i check battery voltage fine then go back it starts fine every time i test the starter craning volts fine i conclude starter relay so i keep removing each relay in turn till i find the starter relay and swap it with another relay. i know go to check codes now all cleared but i have a power steering fault with no codes red warning light and wording on dash. so i disconnect battery for 5 mins retry no ecu fault codes but still steering fault steering performs normal . so is the original fault likely to come back ? how do i clear original fault? i should add i disconnected a few wires while investergating any help greatfuly received
