oliviababy
hi folks, problem. punto 1.2 2001 73000mile. When starting car seems to mis and try to stall. give it some throttle and then everything is fine (bit of judder when pulling away but believe this to be clutch plate). Engine light is on and code is P0351, primary/secondary A coil circuit? car has had new plugs, coils, and belt kit about three thousand miles ago. Coils were changed due to rough idle and known common fault. I'm pretty good on the mechanical side of things but electrics i need some help. any ideas?
