Hi
I had a fuel consumption problem with fiat punto 1.1 1998. I have replaced the plugs, leads, oil, oil filter, fuel filter, and the cooling water. neither of those worked out . I suspecting that the problem maybe in the fuel injector; it might be blocked! could that be the problem? does the injector cleaners work in this situations and how to use those cleaners usually if the works??
I also have done free driving test and there is no problem!
Any other suggestion what might be the problem?
thanks
thanks
