| Need Advice Please please help my girlfriend 2001 punto lost all power steering found out it was the power steerng motor so i bought a recon steering coloum im going to fit it myself with the help of haynes workshop book but allas the old igintion switch is still on the coloum and i have no key so what im asking is if i change the barrell from my gf punto on to the new steering coloum will this have any affect on the immobiliser as the steering colum is complete ready to bolt on thanks for reading hope ye guys can help me
| FFFTW! | Re: Need Advice Please The plastic holder for the barrel is mounted to the column assembly with 2 rounded off bolts. Using a hacksaw blade i managed to make a slice down the middle so i could use a big flat-headed screwdriver on it and took them out like that on both columns, then just switched the entire plastic bit over. Thats the easiest way to do it if you dont have a key. and no immobiliser issues
__________________ If my post has helped you, please click the Thanks button ![]() | ||
| The following user says "Thank You!" to Xen for this useful post: | ||
punto1979 (14-05-2008) | ||
| | #4 | ||
| Re: Need Advice Please that cool thanks also did you use your old power steering ecu or the one that came on the recon part thanks for the welcome
| | #5 | |||
| Cinq gone, Uno asylum! | Re: Need Advice Please Another thing you can do is to drill a hole in the centre of each sheer bolt, then use a screw extractor to get them out. I managed to do this on an old Ford Cortina except I used the tang of a file instead of a proper extractor! Welcome to FF by the way ![]()
__________________ ![]()
| The following user says "Thank You!" to 1986Uno45S for this useful post: | ||
punto1979 (15-05-2008) | ||
| | #6 | |||
__________________ If my post has helped you, please click the Thanks button ![]() | |||
| | #7 | ||
| Re: Need Advice Please thats cool thanks guys for all your help and again thanks for the welcome all i have to do now is fit it and see how i get on
| advice please.... | Alex B | I.C.E | 1 | 28-04-2006 15:48 |
| advice please | sportingchinq72 | Cinq/Sei > Technical | 5 | 10-03-2006 09:45 |
| Need Advice | darkcircuitUK | I.C.E | 35 | 05-07-2005 12:54 |
| A little advice. | Sei S | Punto > Styling | 3 | 28-06-2005 10:43 |
| Advice Please | darkcircuitUK | Leisure Lounge | 29 | 21-06-2005 23:27 |
