Published by frenchwood 06-10-2006 | |||||||||
| The following user says "Thank You!" to frenchwood for this useful post: | ||
custard (19-04-2010) | ||
Posts: 2 Thanks: 0 Trader Rating: 0 | Re: how to check driveshaft wear Hi, had a collapsed nearside constant v/joint replaced witth punto, mine is Selectra.Ran 4 8 mile no jut judders violently in drive.A NY HELP. Cheers Yorki
Posts: 6 Thanks: 0 Trader Rating: 0 | Re: how to check driveshaft wear Excellent post. Before i remove the driveshaft on my punto, how difficult was it to remove (i realise the difficulty is all relative!) and are there any gotchas in the Haynes instructions? Many Thanks
| | #3 | ||
Posts: 1 Thanks: 0 Trader Rating: 0 | Re: how to check driveshaft wear thank you for that information very good
| | #4 | ||
Posts: 214 Thanks: 14 Trader Rating: 0 | Re: how to check driveshaft wear Remember to use a purpose made CV joint grease, these are high temp greases if you use a standard grease it will break down inside the joint and become to sloppy to lube the joint, which will make the joint open to ware again!
__________________ Little Green 1200 CC machine | ||
| | #5 | ||
Posts: 57 Thanks: 2 Trader Rating: 0 | Re: how to check driveshaft wear Could a sticking or worn cage joint, cause the car to start shaking on the front end while accelerating between 55mph and 80mph. When I stop accelerating through these speeds, all shaking and juddering stops. Also today I have had to change my 2 front tyres as they were both worn badly on the inner thread. Tracking is fine. Wheel balance was fine aswell, before new tyres were fitted. Its had new track rod ends and wishbones. So I think it must be a faulty drive shaft. The car is a 1.9 jtd stilo estate 54 plate.
| Currently Active Users Viewing This Article: 1 (0 members and 1 guests) | |
| Article Tools | Search this Article |
| Article | Article Starter | Category | Comments | Last Post |
| | Mazetrix | Marea | 1 | 30-08-2006 20:13 |
| | anthonytutton | Stilo | 9 | 11-08-2006 18:27 |
| | MrBlonde | Panda (Classic) | 18 | 07-05-2005 10:43 |
| | batch | Punto | 5 | 15-04-2005 16:48 |
| | zokipet | Punto | 3 | 22-02-2003 03:37 |
