| MG ZR Owner :) | Re: Home Alloy Wheel Refurbishment/Re-Spray Feel free to share any tips/techniques folks. | ||
| | #3 | |||
| | #4 | ||
| MG ZR Owner :) | Re: Home Alloy Wheel Refurbishment/Re-Spray A bigger picture of the finished rim so you can really see the finish. | ||
| | #5 | ||
| ate too much | Re: Home Alloy Wheel Refurbishment/Re-Spray tip i was told(but never tried)was to cover the tyre in washing up liquid so after spraying oyu canjust wash off any over spray
__________________ need to contact a mod? click me _need to contact admin? click me_FAQ's_ Guides_events ![]() Want +20BHP for £2? | ||
| | #6 | ||
| All Hail the Woodsman | Re: Home Alloy Wheel Refurbishment/Re-Spray Good work. Wilkinsons/Wilko do basic primer/silver/lacquer spray cans for about £3.50 so a way to save a bit of money. A small tip I was given was to use knifing putty to fill scraps and scars in the wheel and sand level with wet n' dry.
__________________ Alfa Romeo 156 GTA / Strada 130TC (currently undergoing restoration) www.strada130.com | ||
| | #7 | ||
| Re: Home Alloy Wheel Refurbishment/Re-Spray Hi, Thanks for the informative article, can you help with a couple of questions :- What sort of abrasive pads did you use, did you do it by hand or machine ? How do you tell when you are through the laquer coat ? Cheers Chris
| | #8 | ||
| Re: Home Alloy Wheel Refurbishment/Re-Spray I, also have done this recently... Works a charm... Also did this for my XR3i and 205gti... Wheel on left is original condition, on right is complete. I chose not to laquer, as the paint i used was metallic radiator pain, and gives a good enough finish without laquer. I did however wet them back with some 2000 grit to get a smooth finish.
Last edited by frenchwood : 31-08-2006 at 22:27. Reason: - Missed text coz i'm a muppet.... | |||
| | #9 | ||
| Re: Home Alloy Wheel Refurbishment/Re-Spray You dont need a primer/base coat... its extra work for nothing... and also you dont really need lacquer, but it helps protect against stone chips if you do use it...
| | #10 | ||
| ate too much | Re: Home Alloy Wheel Refurbishment/Re-Spray and why dont you need primer?
| | #11 | ||
| primer helps to show up any imperfections in the alloy ,so thats one bonus ..plus it also helps the paint to stick to the wheel ...so correction you DO need primer. ![]()
| | #12 | ||
| Chasing Cars | Re: Home Alloy Wheel Refurbishment/Re-Spray Yes I agree you should always use primer, especially on alloys. Also laquer is a must or it will chip and flake like buggery. Im doing this on my 15" Mk2 Punto Sporting alloys at the weekend so Ill put up a guide in the punto section. Ill go into detail about fixing curbing using filler .Good guide
__________________ ![]() Present: 05 Punto Sporting 1.4 16v | ||
| | #13 | ||
| Re: Home Alloy Wheel Refurbishment/Re-Spray Awsome guide.. I was thinking of getting some paint the same color as my car for the alloys.. might be to much but when #i get the pics up decide for yourselves
| | #14 | ||
| Join Date: Apr 2004 Location: stoke-on-trent, United Kingdom.
Thanks: 0 Trader Rating: (0) | Re: Home Alloy Wheel Refurbishment/Re-Spray You can use a number of tecniques to cover the tyre, masking, cover with thin coat of PVA glue (it just peels off when dry) and Grease (any type of cheap grease) - if using grease - DO NOT GET ON TREAD OF TYRE! use panel wipe to remove grease residue from side wall after
__________________ i love novas but its time for a change | ||
| Currently Active Users Viewing This Article: 2 (0 members and 2 guests) | |
| Article Tools | Search this Article |
| Article | Article Starter | Category | Comments | Last Post |
| Alloy Wheel Repairs | col0161 | Garages | 11 | 20-09-2005 21:17 |
| Alloy wheel for Fiat Marea | kk | Parts for Sale | 0 | 12-08-2003 19:43 |
| Alloy wheel offset | DJHarvee | Punto > Styling | 3 | 24-07-2003 03:36 |
| fiat punto 15 inch alloy wheel mark 2 | jarjarmustdie | Parts Wanted | 0 | 05-03-2003 14:52 |
| alloy wheel wanted for brava | RobW | Parts Wanted | 0 | 26-06-2002 22:01 |
