The FIAT Forum
Celtic Tuning - ECU Performance Remap Specialists
Go Back   The FIAT Forum > Guides > Miscellaneous Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->FAQ - De-badging<!-- google_ad_section_end -->
FAQ - De-badging
Published by Little Red Devil
29-09-2005
FAQ - De-badging
Right you will need...
  • Car with badges on
  • Credit card or thin card of the same propotions.
  • Warm water with a small amout of soap in
  • Also a hairdryer can be used but not essencial
  • Tcut and cloths
  1. If using the hairdryer gently heat over the badge.
  2. With the credit card push it behind the badge and press into the adhesive
  3. Continue doing this in a circular motion around the badge.
  4. Eventually the badge should come off easily.
  5. Soak the area with the water/soap mix and gently with the card ease as much of the adhesive off.
  6. Once most of the adhesive is off use the Tcut to treat any faded paint and it will also remove the rest of the adhesive with a little elbow grease.
Please do not reply to this thread as i hope it will be made sticky.
if there is any additions you would like to make please PM me and i will update acordingly.
Article Tools
Old 23-11-2005
Trader Rating: (0)
Re: FAQ - De-badging
i de badged mine hot soapy water an a old credit card came off a treat but i cant get my mangolish sticker typa thing off i dont no how to wonder if any of you have came across this problem?
luke64 is offline
Old 19-12-2005
Simplify & Add Lightness
H2DaE's Avatar
Trader Rating: (1)
H2DaE has donated! United Kingdom
If there is quite a lot of glue that is hard to shift left when you take the badge off, you can also use Jelsol on it. Just spray it over the glue and leave it for a few minutes, then just slide the credit card underneath it and it should come off pretty easily
Mk2 Punto 1.9JTD - GSR/ChippedUK tuned - 118bhp/187lb/ft
Want a set of Sporting Alloys?
H2DaE is offline
Old 26-05-2006
Cinq's Dying :'(
SkinzCinqSporting's Avatar
Trader Rating: (2)
SkinzCinqSporting has donated! United Kingdom
Easing oil (WD40) is also good for removing left over glue
Gaz Roberts
My Ad's
SkinzCinqSporting is offline
Old 24-07-2006
Trader Rating: (0)
Just done my Stilo, used a wallpaper steamer, took the plate off the steamer and worked the end of the hose round the badges, they just came off nicely without any effort.
moshchops is offline
Old 28-12-2006
crabbo_1's Avatar
Trader Rating: (0)
I used a rubber drill attachment thing (pinstripe removal tool) to remove the glue...works wonders
crabbo_1 is offline
Old 04-03-2007
Trader Rating: (0)
white spirit and credit card good aswell, rub a WS soaked cloth on the glue, leave for 2 then rub for 10 and it will take it of easily
jamiejamied is offline
Old 05-03-2007
Pick a window,your leavin
ChrisMClark's Avatar
Trader Rating: (0)
ChrisMClark has donated! United Kingdom
Intensive bug and tar foam works well to loosen it, then when dry just rub it vigorously with your finger and it'll come off.
Please use the 'thanks' button if I've been helpful And let me know how you got on!
03 1.2 Stilo 3 door Active, GSR Induction with aluminium oil catch tank. OMP Braking, NBM Woolford braided hoses, Boge Turbo struts, Koni -35mm Springs,17" BSA Manik Rims on Federal Rubber, Blue calipers, Blue Leather gaitors.Back on MSN, see my profile for address.
ChrisMClark is offline
Old 07-01-2008
Davey Prater's Avatar
Trader Rating: (0)
I can recommend not using a hairdryer at any point whilst de-badging, for one it means you need to be near a power socket and two, it took me a good half an hour just to heat the glue enough to ram the credit card behind it. After that I got bored and left the other 2 badges. I shall remove them using these methods now.
Cheers.
Davey Prater is offline
Old 29-01-2008
joe-bloggs's Avatar
Trader Rating: (0)
joe-bloggs has donated!
Ive been told petrol works a treat to take things like old glue off by a feller that fits windows for autoglass
joe-bloggs is offline
Old 30-01-2008
Fostar's Avatar
Trader Rating: (0)
he's not wrong !!
Bring it on corsa's !!
Fostar is offline
Old 13-02-2008
Trader Rating: (0)
Talking Re: FAQ - De-badging
use a hair drier, then move a bit of fishing line side to side down the back of the badge, remove the excess glue with a bit of your missus's nail varnish remover! t-cut in if you can still see ghost letters
bigadz is offline
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Article Article Starter Category Comments Last Post
Looking for suspension FAQ - broken link ChrisPa Cinq/Sei > Technical 3 29-05-2005 07:56
Fiat Panda FAQ (ongoing) smokeme Panda (Classic) 2 10-05-2005 21:32
fiat panda FAQ smokeme Panda (Classic) 7 31-08-2004 01:32
fao pete on FAQ custard Cinq/Sei > Technical 1 19-01-2004 16:42
I think we need a FAQ about alloys! Sando Cinquecento / Seicento 1 21-10-2003 01:29
