The FIAT Forum
Go Back   The FIAT Forum > Guides > Miscellaneous Guides
Comment
Article Tools Search this Article
<!-- google_ad_section_start -->Front Caliper Overhaul<!-- google_ad_section_end -->
Published by kritip
29-01-2008
The Rebuild Kit
Typically kits come with all the rubber seals and some grease for slide parts.
If you need guides/slide, pistons or bleed valves (nipples) they are not normally included.
In my kit you can see:
  • nipple cover
  • dust boot
  • fluid seal
  • grease for slides
  • slide housing
  • slide housing caps
I also had spare bleed valves as well, though not shown.
Contents
Article Tools
<<  <    Next Page: Cleaning (Page 4 of 7)    >  >>
Comment
Currently Active Users Viewing This Article: 1 (0 members and 1 guests)
Search this Article:
You may not post new articles
You may not post comments
vB code is On
Article Article Starter Category Comments Last Post
Cinq front caliper removal lattelinz Cinquecento / Seicento 1 01-01-2008 22:30
Howto change wishbone front bushing TBMonsen Marea 10 20-12-2007 12:25
What is the size of Marea's front door speakers? ibopasa Marea 5 12-03-2007 16:35
brake caliper overhaul arc Lets Talk FIAT 17 18-12-2006 21:14
Booost!!! antsuno2 Uno 8 26-11-2006 13:12
