Lamps by Post - For all your lighting needs
Comment
Guide Tools Search this Guide
<!-- google_ad_section_start -->Fitting Semi Air Suspension To Fiat Ducato Motorhome<!-- google_ad_section_end -->
Published by eor
13-07-2007
Unrated
User Rated:Unrated
Late Ducato/Boxer Installation
FirestoneTM is the biggest producer of air assisted systems who market theirs as Drive-RiteTM. They are basically the same system/components as AirideTM! one of the alternative systems.
These systems are well designed for most people to fit themselves as no special tools are required.
The vehicle I fitted this system to, belongs to Mike and Carol. They have a very nice motorhome on Fiat Ducato chassis. For this job the following components are supplied by Firestone.
The pictures you normally see of these air assistant suspension units have brackets to mount the top of the bellows on the side of the chassis rail, however on the Sevel chassis there's enough room to mount the bellows between the chassis and the leaf spring, hence the different brackets. The bag contains all the necessary air fittings, nuts, bolts and cable ties to clip the hose up tidily.
I've loosely assembled the units to create the following photo, so that you get an idea of how its assembled without the vehicle parts blocking the view.
As you can see from the first photo, you get a box of bits. With these bits you have to assemble them your self.
Before actually working on the vehicle you need to screw in the right angle air fitting to the bellows, then fit the top bracket AFTER the air fitting, then the bottom bracket. The air fitting already has a dry sealing compound on the threads, so no need to add PTFE tape. Some of the fixing bolts also had some sealing/anti shake loose compound on them, however I added some of my own stud/thread-lock to be safe. The air fittings are made from brass, so don't try to over tightening them, otherwise they will snap off. None of the fixing screws were high tensile, again if tightened too much, they will either snap off or strip the threads. If your not experienced with tightening up fixings, do use a torque wrench to avoid over-tightening.
The first thing you need to do with the vehicle is raise the back axle. Some people would spend time jacking the vehicle up and placing it on axle stands and removing the wheels...
NEVER WORK UNDER ANY UN-SUPPORTED WEIGHTS
I took the easy route and reversed the vehicle up on to some ramps, these raised the back axle by about a foot. As this gave me plenty of working space to access the axle and springs, I didn't go to the trouble of wasting my time to remove the wheels. In fact if you do try to work from outside the vehicle without the wheels, you do have to reach past the brake drums, which isn't easy.
After getting the vehicle in to a suitable safe working position you need to remove the original bump stops. These are the rubber cones which sit between the axle and the chassis as shown below.
These are held in place with a single 10mm threaded stud. This is where the hammer comes in. You could use some Stilson's (large pipe grip thingies), but not many people will have access to such a large tool. Not to worry, the easiest and quickest way is to use a hammer and cold chisel (or bit of bar). You simply rest your chisel at an angle in one of the notches and knock it with the hammer to rotate the bump stop as shown below.
Although my chisel is not actually shown in the notch, you should be able to get the general idea of the operation and angle to work at. You do need to turn the bump stop the correct way to loosen it off, so when your looking at it with it hanging from the chassis, you need to rotate it so the side your looking at goes from right to left. After about half to a full turn, you should be able to turn it by hand so that it eventually spins out.
[Yes all my tools have been painted pink!! They'll shine out at any car boot ;o) ]
After discarding the bump stops, fit the top brackets to the chassis using the single bolt supplied (again I added some thread locking compound). Do make sure it's square to the chassis, otherwise you will encounter problems when you come to mount the bellows assembly.
With the top mount in place, you can now insert the bellows assembly between the chassis and axle. I found the gap a bit tight to compress the bellows enough to ease them into place. This is the time you will wish you had supported the vehicle on the chassis, rather than on its wheels as that will increase the gap. One method you could use to increase the gap whilst the vehicle in on ramps, is to place a scissor type jack between the chassis and spring (not the chassis and axle, as that's where you want to place the bellows!) and open the jack up to expand the gap. Since the vehicle is well supported on the ramps, it can't go anywhere, but do take care not to allow the jack to slip out whilst your operating it. The method I used to increase the gap was to use a high lift jack. Basically its a specialist jack, normally used by farmers, forestry workers and 4x4 off-roader type folks (I'll let you decide - lol) which is a ratchet jack and in my case is four foot tall. With this jack I raised the body slightly by jacking under the vehicles tow hitch.
With the bellows in position, its a simple task of inserting the top location bolts and securing to the axle and spring with the long fixing bolts and brackets. Once its all tightened down and rechecked you can install the pneumatic pipework.
If your not going to go for the extra expense of a gauge and valves in the cab, its simple enough to run the pipes from the bellows to the filler points. There's all sorts of places you can mount the fillers (not too far from the axle as only a limited amount of hose is supplied by Firestone) like drilling two holes in the bumper, or making your own bracket to mount them under it, the best place I have found is in one of the external lockers. However Mike and Carol wanted a gauge and valves in the cab, at least it will stay clean and be easily accessible.
Again the valves and gauge assembly can be mounted in various places, but it was felt the best location was in the driver door foot well as shown below.
Firestone are able to supply their own valve and gauge assemblies, but none allowed for the hoses to approach the assembly from the side. I have seen quite a few, but most are mounted on their side and don't quite look right. Anyway I had supplied photos to Mike and Carol with hoses approaching vertically, but the one above was felt to be more aesthetically pleasing as the gauge was the correct way up, and with the hoses approaching from the side, it was easier to mount the assembly closer to the corner of the footwell, thus being less obtrusive.
On the close up view below, I have colour co-ordinated the valves and hoses to make it easier to remember which valve operate which side of the vehicle (with road marker posts, red is always on the right, right ;o) ). The tyre inflation valve is where you inflate the bellows. I initially had the valve facing out towards you, but after testing in situ, we felt it was better as shown below.
The hose connections are real simple to use, as providing you have cut the hose reasonably square, you simply push the hose in to the fitting until it stops. To release, you have to push the coloured ring in to the fitting, then pull the hose out. They do seal extremely well, though if they do leak slightly, increasing the air pressure for a short period usually does the trick.
To complete the pneumatic installation, its a matter of running pipes from the bellows to the cab. I won't bore you with photos of every cable tie, however I'll run through a couple. The one below shows the hose running from the bellows to a cross member. To add protection to the hose, I ran the hose through a larger hose (green bit) to help avoid any chaffing.
The shot below shows the run from the back of the vehicle up to the cab. Where the hoses run in to the drivers door well, I ran them through larger hoses as its twisted around various objects and through holes which I drilled to gain access to the door well. Inside the cab you will notice there is no slack hose, this can be a real pain if you need to work on the system for any reason, so to overcome the lack of slackness, I left a small loop of hose along the chassis.
With all the pneumatics finished, the brake load sensing valve (LSV) needs to be checked and adjusted if necessary. The LSV is shown below (left arrow), and actuated by a lever (right arrow)
(The photo is of an early chassis, not a Ducato/Boxer chassis, but the LSV system is basically the same)
The LSV is plumbed in to the rear brakes and controls the amount of brake pressure applied to the rear axle. Through levers, it senses the height of the chassis in relation to the axle. With the chassis low, it applies maximum break pressure, but when the chassis is high with no load, it applies minimal pressure. The reason for this is to avoid the rear wheels locking up with no load on the chassis. If this happened going round a corner, you'll end up with a situation like a handbrake turn and find the rear of the vehicle overtaking you. With motorhomes, they are always loaded (you never go home and remove the body, or do you?) so the LSV quite often seizes up. Most MoT testers are switched on enough to realize its not an issue with motorhomes so don't worry about it.
With the semi air suspension lifting the body away from the axle, there is a chance that the LSV thinks there is no load on the rear axle and starts to limit the braking capacity. There are kits available to counteract the LSV getting it wrong, but these are generally only fitted to empty vans or flat bed trucks where the load is removed. To avoid the LSV getting it wrong on a permanently loaded chassis (as with a motorhome), you'll need to alter the LSV linkage. On the rear axle you'll find a slotted/slider adjuster, as pointed out by the red arrow below.
(View from front of vehicle, towards the rear axle)
(This photo is a close up of what's pointed out in the photo above)
If not already done, as was this vehicle, you need to loosen the fixing screws in the middle of the slider, and move the two halves apart as shown above. If your unsure of this, and its effect on the brakes I thoroughly recommend you pump up your suspension to its highest position and have your brakes tested at a MoT station (Not sure, but I don't think there is a charge for this), then at least you'll know whether its set correctly or not.
That completes your installation, and your system is ready to use.
The two photos below show the same bellows deflated, not fully because the spring is still capable of providing support to the chassis. Then to the right, inflated but not to capacity.
Unfortunately my photography skills don't show the finished result to its best, perhaps if the vehicle was a dark colour I may have stood a chance at showing the rear wheel arches to their best. Mike even tried with the shots below, we did discuss merging a high-lighted wheel on top of the original, but I've chickened out for now and placed a high-lighted section within the main photo.
Anyway the first photo below shows the vehicle with the wheel sitting inside the wheel arch, where as the lower photo has a clear gap between the wheel and arch.
The differences above may not seem sufficient, mainly due to the limited effective expansion length of the bellows, but the effective pressure the bellows can apply between the chassis and axle is quite significant, thus lifting the body back into its original ride height.
Putting the ride height to one side, everyone who has had air assisted suspension systems fitted to their vehicles all say they are impressed with the improved ride, improved cornering and less prone to side winds and buffering by large HGV's
If your interested in fitting the above to your own vehicle, we can supply them via our on-line shop. Costs vary, but for a Fiat Ducato/Peugeot Boxer/Citroen Jumper 1994 onwards we can supply them for £299 (without gauge and valves, but including delivery)
A good starting point for what pressure to inflate your air springs to, try 40psi and experiment up and down from there.
Always have a minimum of 5psi in the air spring when not being used for long periods.
DON'T jack up the body with any pressure above 5psi in your air springs (jacking up the axle will be fine).
Disclaimer
The information provided on this Website site is offered with no warranty as to the authenticity, suitability or competence of the individual, company or service quoted here in. This Website shall not be liable for any damage or difficulty, direct or indirect, arising from utilisation of the information contained within these pages.
Old 09-08-2007   #1
Re: Fitting Semi Air Suspension To Fiat Ducato Motorhome
By the way, the above information came from www.marcleleisure.co.uk (with permission)
eor is offline Reply With Quote Quote
Old 19-12-2008   #2
The above instructions are for Fiat Ducatos 1994 up to 2006 (Firestone Driverite kit), whereas the following instructions are for Kits made by Dunlop and fit vehicles 2006/7 onwards
Auxiliary Air Suspension
Installation Manual For Rear Axle
Air Assistance Suspension Kit
L.D06.C.M
Citroën Jumper X250, 2006—Present
Fiat Ducato X250, 2006—Present
Peugeot Boxer X250, 2006—Present
1. FOREWORD 2. INTRODUCTION 3. VERY IMPORTANT NOTES 4. COMPLETE ASSEMBLY 5. INSTRUCTIONS FOR INSTALLATION 6. Attachment of Top Plate and Tube to Bellow 7. Removal of Bump Stop and fitting of Fill Plate 8. Upper Attachment of Bellow 9. Installation of Lower Plate 10. Lower Attachment of Bellow 11. Fitting of Inflator Console 12. Tube Connection and Disconnection, Cutting and Routing 13. Spring Inflation 14. Spring Alignment 15. Maintenance 16. Installation Drawings 17. EPILOGUE
1. FOREWORD
This manual provides instructions for the installation of an auxiliary air suspension kit, developed specifically for the Citroën Jumper X240, Fiat Ducato X240 and Peugeot Boxer X240 (each introduced June 2006). To ensure correct installation of the kit, it is strongly recommend that these instructions are read thoroughly before commencing any installation work. Installation should only be carried out by a suitably qualified mechanic or specialist installation facility. Dunlop Systems and Components will not accept any responsibility for faults or defects arising from incorrect installation, which automatically renders the guarantee invalid.
IMPORTANT : Manufacturer’s Declaration Form
A manufacturer’s declaration form is provided with your kit. Following installation of the kit please ensure that this form is completed, signed by a qualified fitter and returned to Dunlop Systems and Components.
2. INTRODUCTION
Thank you for choosing an auxiliary air suspension kit from the range offered by Dunlop Systems and Components. Auxiliary air suspension is fitted in tandem with the standard steel springs of the vehicle suspension, and provides enhancements in terms of both the stability of the vehicle and the comfort of the passengers…
Vehicle Levelling
Simply by varying the air pressure in the springs, the vehicle can be levelled both front-to-rear and side-to-side. Keeping the vehicle level optimises stability, ensures correct headlamp beam distribution and reduces tyre wear arising from uneven distribution of weight.
Straight Line Stability
Straight line stability is greatly increased at higher speeds, and when subjected to buffeting from cross-winds or large overtaking vehicles.
Reduced Body Roll
Body roll when cornering or negotiating roundabouts is significantly reduced.
Fatigue Reduction and Wear Compensation
Suspension fatigue is reduced, so helping to prevent leaf springs from sagging under repeated or constant loading.
Any sagging already present can be compensated-for. This is a particular benefit for motorhomes, which are always fully laden.
Ride Comfort
Air springs help to absorb shock loads from uneven road surfaces, therefore general ride quality is much improved.
Gross Vehicle Weight (GVW)
Air assist kits are not in themselves designed to increase the gross vehicle weight (GVW) rating of a vehicle. They do not legally allow for carriage of a load greater than the carrying capacity stated on the data plate of the vehicle.
Do not exceed the maximum load specified by the vehicle manufacturer…
¨ to avoid compromising passenger safety
¨ to prevent possible damage to the vehicle
¨ for legal reasons
Load Sensing Valve (LSV) Adjustment
If your vehicle is not fitted with an antilock braking system (ABS) then it will have a load sensing valve (LSV) to automatically adjust braking force under varying load conditions. This valve must be adjusted immediately after the fitting of an air assist kit and before the vehicle is driven again on public roads.
If the LSV is not adjusted following the fitting of an air assist kit, it may misjudge rear load conditions to the extent that the braking pressure applied to the rear brakes is not correct (e.g. the rear wheels may lock with no load on the rear axle). The consequences of this in terms of vehicle stability and safety are potentially serious.
Vehicle Uprating
Despite the above words of caution, it is possible to upgrade the weight rating of your vehicle. This must be carried-out by a specialist supplier that will…
¨ carry out any necessary modifications in addition to fitting the air assist kit
¨ complete documentation as necessary to inform the Vehicle and Operator Services Agency (VOSA) – a mandatory requirement
¨ supply and fit a new weight plate to replace the original plate supplied with the vehicle
This process applies to United Kingdom registered vehicles. The process in other countries may be different.
Safety Guidance Note
The following very useful guidance note is available for free download from the Health and Safety Executive (HSE)…
PM85, July 2007 Safe recovery (and repair) of buses and coaches fitted with air suspension
The uniform resource locator (URL) for this document is…
http://www.hse.gov.uk/PUBNS/pm85.pdf
The complete bellow and bracket assembly is shown by the diagram below...
Number Part Number Description Quantity 10.07.00.1.03 Fill Plate 2 10.07.00.1.02 Upper Clamping Brackets 4 10.07.00.1.01 Upper Plate 2 10.07.00.1.04 Lower Plate 2 SA.LB.170-2 Air Bellow : 170/2 2
Preparation and Precaution
Before beginning installation, ensure that you have sufficient clearance between the axle and the chassis. Use a jack if necessary. Install at one side of the vehicle at a time.
Pay attention to your safety at all times during installation - always use axle stands to support the vehicle!
The following instructions make reference to the diagrams on pages 16 to 18 inclusive.
5.1 Attachment of Top Plate and Tube to Bellow
i. Attach the upper plate to the top of the bellow (i.e. the end without the air inlet / exhaust port) using four countersunk screws—Figures 1 and 2.
ii. See Section 5.7 - “Tube Connection and Disconnection, Cutting and Routing” : Connect a tube to the bellow by pushing the tube into the air inlet port on the underside of the spring and then hand-rotating the tube by one screw turn—Figures 1 and 2. Use black tubing for the left-hand bellow and blue for the right-hand bellow.
5.2 Removal of Bump Stop and fitting of Fill Plate
i. Unscrew and remove the bump stop — Figures 3, 4 and 5. The hole vacated by removal of the bump stop will be used for attachment of the fill plate.
ii. Attach the fill plate using a single M10 x 1.25 x 25mm bolt and M10 spring washer—Figures 6 and 7.
5.3 Upper Attachment of Bellow
i. Insert the two upper clamping brackets into the recess in the underside of the chassis rail. Slide them ‘legs first’ towards the bracket now housing the fill plate until they come to a stop with the legs slotted into the space between the chassis recess and the bracket—Figures 8 and 9.
ii. Attach the bellow upper plate to the upper clamping brackets using two M8 x 20 bolts and two M8 washers—Figures 10 and 11. Do not fully tighten the bolts at this stage because the bellow may require alignment once inflated (Figure 19, Section 5.9).
5.4 Installation of Lower Plate
i. Remove the U-bolts that attach a clamping plate to the leaf spring, and then remove and discard the plate itself — Figures 12, 13 and 14
ii. See figures 15 and 16 : Place the lower plate over the leaf spring paying attention to orientation—see arrows on Figures 15 and 16. Place the U-bolts removed in the previous step over the lower plate and through their original mounting holes. Secure the plate against the leaf spring by reattaching the nuts and washers removed during the previous step (or by attaching new ones of the same size)—Figure 16. Tighten each nut to torque 110Nm (81lbf.ft).
5.5 Lower Attachment of Bellow
i. Feed the air tube through the slot in the lower plate and out towards the centre of the vehicle—Figure 17.
ii. Attach the bellow to the lower plate using two M8 x 16mm bolts and two spring washers—Figure 18. Do not fully tighten the bolts at this stage because the bellow may require alignment once inflated (Figure 19, Section 5.9).
5.6 Fitting of Inflator Console
Standard
Option 1
Option 2
Option 3
Vehicle Fascia Console
Your kit is supplied with one of the inflator console options shown above…
· ‘Standard’, having two valves only (above, top-left)
· ‘Option 1’, ‘Option 2’ or ‘Option 3’, having both valves and pressure gauges
· having both valves and pressure gauges and specially designed to fit into the fascia panel of the vehicle (‘Vehicle Fascia Console’)
Mount the console in a position of your choice whereby it is firmly fixed, has some protection from the environment (particularly important for the console with gauges) and is easily accessible. Suggested possible locations include...
‘Standard’ Console…
· on the rear bumper
· at the rear beside the license plate
· on the chassis next to a rear wheel
· in a service shutter
· beside the fuel cap
‘Option 1’, ‘Option 2’ or ‘Option 3’ Console…
· in the vehicle cabin, within reach and sight of the driver
· in the wall of a cupboard (motorhomes)
‘Comfort’ Packages
The ‘Option 2’ and ‘Option 3’ panels, as shown above, are each part of a Comfort Package that is supplied with a compressor (and also an air reservoir in the case of the ‘Option 3’ panel) for ease of spring inflation and ride height setting. For further information please ask your dealer.
5.7 Tube Connection and Disconnection, Cutting and Routing
Tubes are connected as shown by the diagrams below...
A.
B.
C.
A. Slide a nut over the end of the tube
B. Push the tube onto the connector as far as possible
C. Feed the nut up to the connector, fully tighten by hand and finally tighten one additional turn using spanners
Cutting
To achieve good sealing and air-tight fitting of tube ends to their connecting parts, it is very important to cut tubing cleanly and squarely. A dedicated guillotine action tubing cutter is recommended, or a craft knife if such a tool is not available. Do not use electrician’s side cutters.
A dedicated tubing cutter - Recommended
Electrician’s Side Cutters - NOT Recommended
Routing
Study the underside of the vehicle and decide how to route each branch of the air circuit…
· To minimise the risk of chafing, avoid running tubing over metal edges as much as possible
· Avoid close proximity to heat sources such as the exhaust assembly
· Choose a route that provides as much protection as possible from dirt, debris and any solid objects that may impact the underside of the vehicle
It is recommended that tubes are guided alongside brake lines as much as possible.
Use cable ties (‘tie wraps’) to secure tubing to the chassis, taking care not to over-tighten them.
5.8 Spring Inflation
Maximum and Minimum Pressure
Maximum Pressure 7.0bar Minimum Pressure 0.5bar
Do not exceed 7.0bar (101psi), which is the recommended maximum charge pressure for the air springs.
The springs may be deflated if the vehicle is to be stored for a lengthy period without use, but a pressure of at least 0.5bar (7.25psi) should be maintained at all times in order to avoid possible compression damage to the springs.
5.9 Spring Alignment
Spring out of alignment mounting plate axes offset
Spring in alignment mounting plates parallel and coaxial
CAUTION!
Before fully tightening the bolts that secure the air spring to the upper and lower brackets, set the vehicle at ride height (spring height approximately 13.5cm) and ensure that the springs are correctly aligned.
5.10 Maintenance
Following installation, it is recommended that all metal parts are coated with a protective substance such as body wax.
The system does not require very much maintenance other than…
¨ to maintain air pressure in the springs. Much like a tyre, the system may lose a little air over time.
¨ to keep the air bellows clean. It is suggested that, when washing the vehicle, the bellows are inspected and cleaned as necessary (preferable by spraying). Look in particular for stones or grit trapped between convolutes, as this may damage the bellow.
5.11 Installation Drawings
No1
No2
No3
No4
No5 28
No6
No7
No8
No9 32
No10
No11
No12
No13 36
No14
No15
No16
No17
No18
No19 Spring out of alignment mounting plate axes offset
CAUTION!
Dunlop Air Assist Suspension kits are available from the UK's only supplier:
Marcle Leisure
Old 26-12-2008   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by eor View Post
but did anyone ask for permission to advertise it here? You have to contact the site owner if you want to advertise this product!
Old 17-12-2009   #4
Hi,is it possable to get this system for a 1986 Fiat Ducato Motorhome it dosen't have rear springs only shock absorbers if so what is the price of the system please.
Nightowl2525@hotmail.com
Nightowl25 is offline Reply With Quote Quote
Comment
Search this Guide:
(G) Air Box Modification polecat Marea 105 09-07-2011 16:28
(G) Airbox on mk2 45 chrisunoman Uno 13 23-12-2004 00:15
(T) air box mod revisited jbackg Marea 1 18-08-2004 00:33
(G) Fiat Bravo (moved thread) sonia cachia Bravo / Brava 7 20-10-2003 03:30
