58 Fiat 500 Pedal Box Removal
Mneeds22
Hi, this is my first post to the group, after a while of wobbling, the clutch pedal in my Fiat 500 has finally snapped at the top. I have removed all of the nuts from the pedal box and have removed the push rod connecting the pedal to the master cylinder.
I am now stuck and can't seem to remove the bar that connects the brake pedal to the brake booster, Im not sure if I need to remove a pin? Anyone who has come across this help would be very much appreciated
Matt
Been quite a while since I changed my clutch pedal but certainly didn't need to remove pedal box. If memory serves, remove clip on pedal pivot shaft and slide pedal off ( having disconnected master cylinder linkage first ) or may need to slide pedal pivot shaft across first.
Sorry can't remember exact details but remember being pleasantly surprised at relative ease of job!
Shouldn't be necessary to remove brake pedal to replace clutch pedal. Panda Fiat workshop manual shows removal of clutch pedal before brake pedal. See pics.
