Technical fiat grande punto gearbox torque settings. HELP NEEDED
kp60bug
hi everyone this is a great forum i'm a new member I got fiat grande punto 1.2 2006 model, just got around changing my input shaft bearing and now I need to put it back together. I was wondering what torque to tighten the bell housing, gear selector, differential housing and rear cover. would really appreciate any help.
Also any advise on whether I should use a instant gasket or liquid gasket would be helpful
MANY THANKS
Hi there [First_Name ?], and welcome on board !!
here are the main torques you need to refitt your gearbox to the engine...
- Oil filler plug, M22 : 2.3 - 2.8
- Oil drain plug, M16 : 1.6 - 2.0
- Engage/select lever, M8 : 1.5
- Casing, M8 : 1.8 - 2.2
- Bell to engine, M12 : 4.8 - 7.2 OR if M10 : 3.6 - 4.4
- Bracket to engine, (M8 : 2.2 - 2.7 and M12 : 5.0 - 6.0) OR if all M10 : 3.6 - 4.4
All values in daNm !!
Regards, Bernie
If someone here helped you understand - or better- fix your issue, hit the thanks icon @ bottom right, it's free and makes us happy...
