Thread Tools
Old 10-01-2017   #1
Grande Punto 2008 fuel cut off switch location.
Hi
My 2008 Grande Punto 1.4 3 door hatchback won't start.
It turns over but will not fire up. I checked for spark and I have one.
It is as if I am not getting fuel through. I ran out of petrol and topped it up again but now it wont start.
Where is the fuel cut off switch on this model?
And would appreciate any ideas. Would a tow start it?
Thanks.
dee121 is offline Reply With Quote Quote
Old 10-01-2017   #2
varesecrazy has donated!
Re: Grande Punto 2008 fuel cut off switch location.
Quote Originally Posted by dee121 View Post
Hi
Thanks.
Hi, and welcome,
turn on the ignition , can you hear a buzzing from under the rear seat..??
that's the fuel pump.. if it's running - you have another issue,
I believe the reset button in on the plastic trim , UK passengers footwell,
near door hinges
here is a helpful thread - IF you are having more trouble - reply to it..
http://www.fiatforum.com/grande-punt...itch-help.html
do let us know what you find..,
Charlie - Oxfod
Old 10-01-2017   #3
Moderator
Andy Monty's Avatar
Andy Monty has donated!
driver side (uk) drivers footwell in the plastic trim there is a hole... (look at the passenger side similar place to the bonnet release pull)
Later models have a reset via the indicator stalk
To reset car operation, follow this procedure:
turn the ignition key to MAR;
activate the right-hand indicator;
deactivate the right-hand indicator;
activate the left-hand indicator;
deactivate the left-hand indicator;
turn the ignition key to STOP
Massive gash
Just a little touch up
Old 10-01-2017   #4
Hi
you wrote,
"turn on the ignition , can you hear a buzzing from under the rear seat..??
that's the fuel pump.. if it's running - you have another issue,"
can you explain what you mean, thanks.
Is there a way of checking if fuel is getting through up to the engine?
Old 10-01-2017   #5
Andy Monty
Is the fuel cut off switch in the drivers side underneath a plastic trim on the side wall of the footwell near the door???
Old 10-01-2017   #6
Could there be an air lock because I ran out of petrol???
Old 10-01-2017   #7
unlikely..
the petrol tank has an electric pump,
it's accessed from under the rear seat..
the fire prevention disables the pump..
it's all covered in that link above..
as I said,
reply to the Grande thread if you need more help
Old 10-01-2017   #8
ok thanks
Old 10-01-2017   #9
Charlie
Old 13-01-2017   #10
any news,??
Thread Tools
(T) Fuel Cut Off Switch Location New Shape Mk2 Bravo davv Bravo 1 11-08-2015 21:16
(T) Fiat 500 fuel cut off switch location ? dalemultiwagon 500 12 12-07-2012 21:09
(T) Fiat Punto 2002 1.2 Active - Ticking over won't start, fuel cut off switch? Flec Punto (Mk2/2b) 8 16-04-2011 16:35
(T) does any1 knw where to find the fuel cut off switch on a 2008 sporting punto bajandrifter Grande Punto 6 26-04-2009 11:46
(T) Punto 1.2 petrol EOBD light stays on (have reset fuel cut-off switch) prassell Punto (Mk2/2b) 3 24-12-2005 02:09
