Technical engine problems.
beppy66
HELP ME,my little 2007 500 has develped engine running problems,on start up from cold the revs go up and down ,then when driving the car is jurking like kangaroo when you take foot off the revs, i have fitted new throttle body,new pedal and done full service,plugs filters,anyone no what the problem could be,its showing no faults in the diagnostics check:c
Hi. Did you perfom a relearn for the throttle body..??
Look in the 500 section for similar posts.
And the Punto 2 guides for the procedure
Charlie
