Lamps by Post - For all your lighting needs
Thread Tools
Old 03-03-2017   #61
Moderator
henseyseries3's Avatar
henseyseries3 has donated!
Re: Hensey's 1242 8v turbo build
Well I thought I'd update even though much hasn't been going on but I feel like I don't put enough information in this thread like I do with the white daily
But anyway carbon canister removed and solenoid cabled tied up out the way
Rear brake pipes all made up not the cleanest way of doing it but it works
Engine bay picture and the fuel pipes I need to sort
Comps have no tyres on now so they can go for a refurb and have my rainsports fitted that i'm getting off @Lecook
Sideskirts fitted yes I do have three need to find myself one passenger side one and then everyone can guess what i'm doing with the second set but would be rude not to test fit the one yellow one I have
And a picture with the long abandoned project would be nice if I could get both done this year but I doubt that lmfao
Likes purf liked this post
1995 Cinquecento Sporting 1242 8v
2006 Mjet GP
1968 Series 2A Landrover
henseyseries3 is offline Reply With Quote Quote
Old 19-03-2017   #62
Moderator
Kv85s fitted seems to rev and idle a lot better now but didn't sort out this strange misfiring I've been having but I've think I've got that sorted but I'll get more into depth with that when I 100% know that's the issue
Also as I let the black rear bumper go with the white Cinq I decided to fit my old bumper back on, just need to find a nice intact yellow bumper now to fit the rear apron in to and have it all painted, and also popped the comps back on just so I didn't have the sat about in the shed getting damaged
I do miss these wheels can't air to get them refuted and tyres on and see it all painted up
Likes Lecook liked this post
2006 Mjet GP
Old 14-06-2017   #63
Moderator
Well where do I start stuff hasn't exactly been done as some might have seen I want to get the landrover finished but there's been small bits done to the Cinq
So first of comps have been refurbished
Then sadly I found a yellow Cinq on the scrapyard so had the rear bumper off for mine
Then decided to place the sideskirt on with a few screws in the ends this keeps them out the way and stops them getting damaged
Also put my cento uk stickers on (another group i help admin for on Facebook so definitely go check them out)
And decided to photobomb there stand and forza in my punto
2006 Mjet GP
Old 25-07-2017   #64
Moderator
I'll be honest I really did lose interest in both the projects, funny really what happens in your life that give you a kick up the arse just wanted to introduce the other halfs Cinq no doubt I'll eventually do a build thread on this
She's had it a few months I think fitted the boot with Barth spoiler over the weekend
But good news because off the above I've got **** loads of enthusiasm to get the Cinq done so stuff has happened
Flexi on center pipe has been changed to stop it blowing not an amazing job but does the job till I can get another one made as will need some other exhaust work sorted to make the tail pipe for the Abarth rear apron
Headlight wiring has been put back to how it should be as someone spliced into the high beam wiring when the spotlights were fitted
Stongflex yellow mount fitted to spare mount still has to be fitted to Cinq
Goodridge Punto gt rear calliper brake pipes fitted this is as you can see not the finished product it's just put together to stop fluid pissing everywhere
Mr cook dropped my 3 rainsport 2 tyres down and some 30mm spax springs so fitted the tyres and a spacesaver and had a little drive up and down the road brakes need bleeding but the gearbox seems okay clutch is abit heavy but I guess that's to be expected really
Fitted the spax rear springs to replace the old ones just a head up for anyone my old springs will be in the classifieds at some point obviously very cheap but may come in handy for someone
Then it'd be rude not to get his and hers pictures aye
2006 Mjet GP
Old 3 Weeks Ago   #65
Moderator
So been pretty busy not much on the Cinq but more on the garage and shed
So plans have changed as some might have seen I've said I've sold my 8vt stuff
I've decided to go 1368 16v yes abit more boring then the 8vt but more cost effective for me and something I haven't built but don't worry my current p75 is staying in the family and going in the other halfs Cinq
I've put down a deposit on a 1.4 16v that's previously been in a cento but sadly the ecu and loom was scrapped with the Cinq
So I'm in need a mk1 punto 16v engine loom and ecu with related imob stuff so if anyone has said items knocking about please please message me
2006 Mjet GP
Old 3 Weeks Ago   #66
Re: Hensey's 1386 16v build
Good effort. Keep it up.
purf is offline Reply With Quote Quote
Old 1 Week Ago   #67
Moderator
So the 16v is in my hands now it's time to clean it up, plans are to take the head off then check the bottom half over new cambelt water pump get the head skimmed new valve stem seals the usual stuff
Then clean and paint the block
As you can see I've got a slight issue with the err aux belt alignment
Also put a deposit on a supersprint exhaust mani that I should hopefully be picking up Friday
2006 Mjet GP
Old 5 Days Ago   #68
Trader Rating: 3
ycming has donated!
This is going to be a really enjoyable experience trust me !
Are you going to use the mk1 head?
If you are, watch out for the supersprint mani the one you got is more likely for the newer head pattern. You can get a flange from Ashley exhaust that will take both stud pattern and reflange the supersprint mani.
Have you also the mk1 inlet manifold?
With the Aux belt issue, try and get a mk1 sporting alternator will that solve it. Just now I am running washers to space the alternator out (using a cinq one).
I am sure you know, you need to grind down the mount on the driver side to give it more room.
I got a set of mk1 loom, I was going to keep spare. Message me if interested.
Also fuel pressure regulator will come in handy.
Ming
Wanted : Nothing at the moment
ycming is offline Reply With Quote Quote
Old 4 Days Ago   #69
Moderator
Quote Originally Posted by ycming View Post
Ming
Cheers Ming it's got it's original 1.4 head with a mk1 punto inlet bolted to it
And I'll let you know about the loom just waiting for the guy I'm in talks with about a loom and ecu kit to get back to me
2006 Mjet GP
Thread Tools
Stilo Stilo ABarth 2.0v turbo build stilo abarth Members Motors 34 28-09-2015 22:35
Stilo 2.0 20v turbo build stilo abarth Stilo 1 15-02-2015 13:51
(T) wolf direct racing 1242 8v engine rebuild (slow build) Lecook Cinquecento / Seicento 15 09-12-2014 19:10
(G) The First UK Marea Turbo? Build thread bulldog5046 Marea 433 19-09-2011 20:45
Marea Turbo build thread Anonymous FIAT Boo Archives 17 14-07-2008 11:06
