Thread Tools
Old 16-10-2016   #16
Moderator
henseyseries3's Avatar
henseyseries3 has donated!
Re: Hensey's 1242 8v turbo build
Well the block cleaned up pretty well
1995 Cinquecento Sporting 1242 8v
2006 Mjet GP
1968 Series 2A Landrover
henseyseries3 is offline Reply With Quote Quote
Old 22-10-2016   #17
Moderator
Typical Saturday for me all going well Click image for larger version
Well it was all going well until I went to put the cambelt doesn't fit my pulleys I ordered it for a p75 and it also doesn't fit the spare p75 pulley I've got in the shed so I guess s4p sent me out the wrong timing belt kit or fiat changed the pulleys somewhere along the lines but got one matched at euro and it's getting dropped of to work Monday at work just gutted I couldn't get her running today but next weekend she will be
2006 Mjet GP
Old 23-10-2016   #18
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
Snowboard Slalom Champion, Skate Boarder Champion
there is 2 different timing belts for a 75.... I discovered as such when i was looking for new belt for my p75 panda conversion. I found somewhere that said upto x engine number and a different belt from the next.. number of teeth on belt is way different so you could just count them on old belt to be sure.... Thinkit was Mister Auto website that had them listed by engine number but i can't remember for sure....
Charmander - Panda Mania 1242 mpi 8v - thread
Unnamed - Panda 100HP - thread
Oberyn - Suzuki Ignis Sport - thread
Some previous cars: Alfa 159, Bravo HGT, Cinq 16v, Sei Turbo, Punto GT
blu73 is offline Reply With Quote Quote
Old 23-10-2016   #19
Moderator
Quote Originally Posted by blu73 View Post
Yeah basically what Euro said when I took the old belt and new belt into them to match it s4ps don't even list another belt for the p75 so I've got a nice new waterpump and cambelt that I can't send back because I've used it ah well lmfao
2006 Mjet GP
Old 24-10-2016   #20
Moderator
Yellow rear lights turned up now i'm a real happy bunny
2006 Mjet GP
Old 25-10-2016   #21
Portugal
Nice that you are doing the p75 mpi turbo, may I ask?
Are you using the 38 mm Throttlebody?
What turbo are you going to use?
Are you going standalone or piggyback?
What compression your running? Decomp plate or other pistons?
I myself just did a P60 SPI swap, wich was alot of fun got me 80 Hp and 110 Nm at the flywheel.
I can't tell from you photo's. Did you do some portmatching while the head was off.
I'm going to follow your progress, looking good, keep up the good work
Jajr2009 is offline Reply With Quote Quote
Old 25-10-2016   #22
Moderator
Quote Originally Posted by Jajr2009 View Post
Cars already got a 40mm throttle body so I'll be using that
Will be on standalone management
Turbo not sure yet as i'm not 100% sure what flange my manifold has as I haven't received it yet
I will be using a decomp plate for now that I think is 2.5mm thick
And nope no port matching as of yet as I haven't heard this engine running yet so want to make sure it's all okay n/a before I and forced induction to the list
It's going to be a case of having the car running and driving n/a then add boost when I've collected everything to do it
2006 Mjet GP
Old 25-10-2016   #23
Portugal
Quote Originally Posted by henseyseries3 View Post
What standalone are you going to use? If this engine preforms well in N/A, what boost pressure do you want to reach and what Hp figure are u aiming for?
Old 25-10-2016   #24
Moderator
I'm leaning towards microsquirt or similar but i'm still in the process of figuring all the little details
And power wise basically the most I can get while keeping it some what reliable
2006 Mjet GP
Old 25-10-2016   #25
Portugal
Did you check out ecumasters det3? In the netherlands it's 199,-. De det3 comes with no map or a 2,5 of 5 Bar internal Map sensor. That's a piggyback or u have the EMU standalone from ecumasters wich is 699,- dunno what the prices are over there.
Old 28-10-2016   #26
Moderator
Well she's runs she's a tooth out and and there a vacuum pipe I let off on the tb that's what's the high idles about but she's nearly running right
And decided to fit some Samsung cree led bulbs to the fog and reverse honestly there bright as **** the yellow lights make them a less bright
Here's another picture for reference in the back of my dad Alfa
So I've ordered stop and tails in the same bulbs
2006 Mjet GP
Old 30-10-2016   #27
Moderator
So sorted the Idle out found out there's a blow on the exhaust from the flexi went through all the gears obviously no test to see if the gearbox is actually any good but it goes though all the gears
Now she's on the drive as had a lovely neighbor moan about the noise strange really as his bike wakes me up at 5 in the morning
2006 Mjet GP
Old 01-11-2016   #28
Portugal
https://youtu.be/NOeSI90Uoeo
Attachment 172872
Neighbours always moan, if it's them making the noise they moan when u moan at them.. circle of moaning 😂
Old 01-11-2016   #29
Moderator
I wouldn't mind if I was limiter bashing it but it was basically idling while I went through the gears
2006 Mjet GP
Old 01-11-2016   #30
I choose you!
blu73's Avatar
Trader Rating: 2
blu73 has donated!
i do hope you told him his bike was loud at uncivilised hours of the morning at to kindly bugger off and mind his own business..
Likes Crashtest33 liked this post
Thread Tools
Stilo Stilo ABarth 2.0v turbo build stilo abarth Members Motors 34 28-09-2015 22:35
Stilo 2.0 20v turbo build stilo abarth Stilo 1 15-02-2015 13:51
(T) wolf direct racing 1242 8v engine rebuild (slow build) Lecook Cinquecento / Seicento 15 09-12-2014 19:10
(G) The First UK Marea Turbo? Build thread bulldog5046 Marea 433 19-09-2011 20:45
Marea Turbo build thread Anonymous FIAT Boo Archives 17 14-07-2008 11:06
