Hi Surchr, you mentioned its only three nuts to undo. What tool do I need to undo these nuts cos the regular spanner doesnt look like it can undo the nuts.
I put a 10mm hex bolt onto a large allonkey as the position of the nuts are stupid and was unable to get the socket set in there, its also tricky with a spanner too... the allonkey with socket on the end makes it very easy to do and no more swearing and bitching when removing the cluster
