Hi Fiatforum
Here’s some of the many specs. on my latest project.
Engine setup:
The engine is a P75 turbo’d with a Van Aaken turbo kit.
Cylinderhead and inlet is flowed and bottom end is fully balanced.
Original SPi injector is fitted on the inlet to run the engine as a standart Cento SPi.
The MPi system is used as boost fueling and it’s much better and more reliable than the cup SPi version from Van Aaken.
The original fuel regulators from both SPi and MPi is used to control the fuel pressure. The pressure is 3.0 bar on the MPi injectors and 1.2 bar on the SPi injector.
The original fuel pump was replaced with the P75 3.1 bar fuel pump.
I used original 1242cc 16v pistons as low CR pistons and this has shown to be a great solution on the turbo setup.
The fuel cut defender is made with a 4.3v Zener diode fitted between signal and ground on the original MAP-sensor.
I used a SMT6 Piggyback from Perfect Power to control the SPi injector, the MPi injectors and ignition.
I didn’t fit an oil cooler cause the oil temp. is always between 80 and 90 degrees on the road – on the rollers oil temp. get up to 130 degrees.
The engine is running 0.6 bar and have covered 5000 km now with no problems at all kicking 105 bhp and 155 nm ATW.
I’m very pleased with the result but I’m still searching for more power.
Have been running 0.8 bar no problem but need to bleed wastegate actuator to get boost stable over 4500 rpm.
Check out the pictures bellow and enjoy
16v piston on the left and the original P75 piston on the right
P75 piston on the left and 16v piston on the right – please note that the 16v piston have a dish shape on the top lowering the CR to 7.8:1
Empty P75 bottom
Fitting the 16v pistons
16v Pistons fitted
Flowed P75 head and inlet manifold
The turbo engine coming together
Oil return and oil temp. mount welded in
Oil temp. sensor fitted
Intercooler fitted
MAP-sensor for boost fueling
SMT6 wired in
RR sheet
Cheers Fiatforum
/tricker
Engine setup:
Empty P75 bottom
16v Pistons fitted
Intercooler fitted
SMT6 wired in
RR sheet
Cheers Fiatforum
/tricker
