The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Marea
Old 11-07-2006   #1
Trader Rating: (0)
Unhappy bump noise when changing gear
Hi just had new clutch but now every time we change gear we get a clunk noise,the garage says its probably movement of worn engine mountings,but it was ok untill they changed the clutch.
Any Ideas do you think they have forgot to tighten something,is it safe to drive,Im a bit of a dodo when it comes to cars as Manuel from Fawlty Towers would say "I know nothing"
swedenora is offline
Old 11-07-2006   #2
jug
blessed are the apostates
jug's Avatar
Trader Rating: (1)
jug has donated! United Kingdom
Re: bump noise when changing gear
gearbox mount needs to be checked and also all 3 gear selector rods where they attach to the gearbox. they're hard to tighten so one or more may be loose or threaded, or the rubber bush in the mount may have been damaged on removal.
also i'd check the fluid level in the gearbox, they may have neglected to fill it sufficiently
jug is offline
Old 14-07-2006   #3
polecat's Avatar
Trader Rating: (0)
polecat has donated! United Kingdom
Hi
How bad was the clutch before? You may not have been putting enough stress on the engine before to move it.
You also have to adjust your driving style slightly with a new clutch as it will be putting load on the gears quicker and you may be beating the synchro.
Can you feel the clunk on the gear stick, steering wheel or seat as well as hearing it?
polecat is offline
(T) Noise from the engine. TheCROW Bravo / Brava 3 06-04-2006 07:17
(S) Gear knob changing was easy. seongtaek Marea 1 17-02-2006 22:14
(T) Another Clutch / gear box issue Zimon Cinquecento / Seicento 15 03-07-2005 13:55
(S) changing gear knob madmish Punto 8 28-12-2004 00:47
(T) 1st/2nd gear noise cspiteri Punto 6 11-05-2003 16:01
