The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Marea
Old 18-05-2006   #1
Trader Rating: (0)
Exhaust change on Marea 2.0l 20v
Exhaust is blowing and its well and truly time for a change! Obviously i want something a little more noise and better looks. Fisrt question would be: anyone fitted after market exhaust to the above vehicle, and what was it, how much did it cost, and who did it?
Second question: If i go for standard exhaust system, how much will this cost?
Also, any suddgestions on where to go for the above work. cheers.
JOFF is offline
Old 18-05-2006   #2
Trader Rating: (0)
Re: Exhaust change on Marea 2.0l 20v
Last one I had fitted was around £200.... start saving......
werdna is offline
Old 18-05-2006   #3
hot hot tamale!
Hellcat's Avatar
Trader Rating: (3)
Hellcat has donated!
You considered a third option? Custom built stainless steel?
Hellcat is offline
Old 18-05-2006   #4
Trader Rating: (0)
Good point! can u give any advice on this option?
JOFF is offline
Old 18-05-2006   #5
polecat's Avatar
Trader Rating: (0)
polecat has donated! United Kingdom
Its an old photo but it gives you the idea.
http://www.fiatforum.com/gallery/sho...00&ppuser=2721
polecat is offline
Old 19-05-2006   #6
Trader Rating: (0)
exactly what i was thinking of!! How much did that beauty set u back?
JOFF is offline
Old 19-05-2006   #7
hot hot tamale!
Hellcat's Avatar
Trader Rating: (3)
Where are you from?
I drove to MIJ on the outskirts of Birmingham for my custom exhaust.
http://www.mijperformance.com Give them a call.
Hellcat is offline
Old 19-05-2006   #8
Trader Rating: (0)
Im from Manchester. Birm a bit of a trek! but if i cant find someone closer, then needs must!! Cheers Bro.
JOFF is offline
Old 19-05-2006   #9
hot hot tamale!
Hellcat's Avatar
Trader Rating: (3)
Manchester! You're practically on his doorstep!!
Hellcat is offline
Old 20-05-2006   #10
polecat's Avatar
Trader Rating: (0)
Powerflow custom build from the cat back. £320.
I got 50mm pipe, a twin 4" oval, the biggest back box they had and lost the centre box. It has a really lovely note now.
polecat is offline
Old 20-05-2006   #11
Trader Rating: (0)
Cheers Dude. Gives me more of an idea! Obviously mine will be a little different as mines a weekend. Funds come next week, so once its on, ill take some pics.
JOFF is offline
Old 20-05-2006   #12
hot hot tamale!
Hellcat's Avatar
Trader Rating: (3)
Do you have a tow bar, or is your bumper still able to roll down? If so that could cause issues for a custom exhaust.
Given mine is a diesel I have no such exhaust vanity problems, and i'm quite happy for it to be mostly hidden behind the bumper
Hellcat is offline
Old 20-05-2006   #13
Trader Rating: (0)
Got a tow bar. Was gonna have this removed as at the mo, it gets in the way of the standard exhaust being attached properely!
The rear box is supported by a rubber connection and currently, due to the tow bar, it is only attached to one of the two holes available. Wondered if the tow bar might get in the way of a custom exhaust?!
May leave it on tho if not in the way.
Cheers for raising that point.
JOFF is offline
Old 20-05-2006   #14
hot hot tamale!
Hellcat's Avatar
Trader Rating: (3)
The plate which bolts to the underside of mine, and has the fingers for the rubber, is only held with one bolt, and one bulge which holds it in the correct direction. I think it's only supposed to use the one bolt hole. I think the other is for LHD cars where the towing eyelet is on the other side of the car?
This plate has to be attached using a bush to hang it lower when the towbar is fitted.
Hellcat is offline
Old 22-05-2006   #15
Trader Rating: (0)
Right! so yours has a rubber around the pipe too! Might be why mine hangs a bit!
JOFF is offline
(T) 2.0L 20V Timing megadan Marea 6 24-12-2005 23:36
Marea 2.0 20v T bob16v Lets Talk FIAT 2 03-12-2005 03:37
(T) Cambelt Change on Marea TD100 OilBurner Marea 12 20-05-2005 14:57
Fiat Marea Engine 40k 2.0 20v Tryfan_Tamer Auction Watch 0 06-02-2005 21:08
(T) Photo how-to: Marea 20v cam belt change fixitagaintomorrow Marea 0 01-02-2005 14:20
