| My radiator cooling fan won't switch off !! Hi, I have a Marea Weekend TD 100 and the raditor cooling fan refuses to switch off. I have had to unplug it. I changed the switch that screws into the radiator , thought that might do it, but no. Any ideas would be gratefully received........Phil
| Hi Phil and welcome to the forum:D Not sure what kind of switch you replaced but... The switch is a neutral feed so an earth on the wiring would keep the fan running. This is the most likely cause on fans controlled from a radiator switch. If you have a temp sensor rather than a simple switch then it could be the relay burnt on.
| | #3 | ||
| Re: My radiator cooling fan won't switch off !! Hi, Yes as the previous messge says, these models have a common problem with the fan relay either short circuiting or burning out the relay contacts so it cant pass any current. i would think this is your problem! Oh and its usy=ually found adj to the battery.
| | Little Red Devil | Cinquecento / Seicento | 21 | 02-11-2007 18:34 |
| | anthemmaster | Bravo / Brava | 6 | 10-04-2004 00:37 |
| | mrs crayon | Cinquecento / Seicento | 12 | 04-02-2004 19:36 |
| | DotSPF | Uno | 6 | 11-11-2003 23:18 |
