The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Marea
Old 13-02-2008   #1
taffy git
gaz.d's Avatar
Trader Rating: (2)
gaz.d has donated! United Kingdom
cant open the boot
I just brought a marea weekend and the boot wont open.
Hopefully garage I getting it from will fix it but if not how can I get open it to try and fix it?
How does the boot open? Does the key turn and pop it open? or is there a button you got to push?
I have been looking for a lever in drivers footwell but dont think it got one
Gaz
Marea Weekend
gaz.d is offline
Old 13-02-2008   #2
Trader Rating: (0)
Re: cant open the boot
You be careful, its bigger than a panda !!!
The weekend doesnt have a lever by the drivers seat, there is a latch on the hatch door. there has been a thread about the bootlock, try searching this forum for it.
werdna is offline
Old 13-02-2008   #3
mach1rob's Avatar
Trader Rating: (0)
Mine was broken too, there's a flap between the number plate lights you push up to open it, mine was just flapping about. previous owner had cut a hole in the plastic boot trim to gain access to the back of the lock to get it open. The catches are on either side and you can't get into them with boot closed from inside hence the hole being cut.
I took the lock apart the other day, there was a small spring that had popped out of a locating hole, cleaned the lot up including the hinge for the handle as that was caked up with dirt and mud, re-assembled and touch wood been fine ever since
It took me about an hour from start to finish, but most of that time was spent finding hidden bolts holding panel on 2 outside, 2x 10mm nut on inside of boot each end, and 2 or 3 bolts across the width (1 is hidden behind the grommet where lock solenoid attaches) and of course not forgetting the wiper blade.
http://www.fiatforum.com/signaturepics/sigpic39130_3.gif
mach1rob is offline
Old 13-02-2008   #4
__________
dave's Avatar
Trader Rating: (10)
dave has donated! Saint Kitts and Nevis
crow bar
Binki
dave is offline
Old 14-02-2008   #5
taffy git
gaz.d's Avatar
Trader Rating: (2)
The button doesnt move. That why I thought it wasnt a button
Will see what happend when I pick it up. Doesnt sound like a hard job to do, just a pita
Gaz
Marea Weekend
gaz.d is offline
Tags
boot, marea, stuck, weekend
I lit up the old boot (and I'm not referring to the Mrs). Creamola Panda (New) 17 11-07-2008 20:56
(T) Boot open warning jimmycrank Stilo 5 14-05-2007 16:35
(T) Can't open Marea Weekend boot - help! gisburne Marea 26 10-07-2006 23:24
(G) boot release (from key) stilo_jason Stilo 19 01-05-2006 14:23
(T) Bravo boot light problem Hellcat Bravo / Brava 6 01-02-2006 22:31
