| | #1 | |||||
| Handbrake Handle Replacement Just a few tips 'n' ideas on replacing the standard handbrake handle. Do not fit any adaptors into the replacement handle until later, all will become clear. I had been thinking about replacing my handle for some time but did not have enough confidence about cutting off the existing handle until Notorious131 posted his experience. I have included an extract from his post below.
I first had to take my new blue gaiter off as it completely covered the handle. Next a cut along the top of the handle with a thin bladed modelling knife, there was a small groove that I followed, it took two or three goes to get down to the metal. The plastic then just peeled off, there were a few patches of glue, but not enough to cause any real problems. I checked the handle over but there was no glue or anything else to clean off. :D The button is captive in the handle so no problems there. You can still use the handbrake with the handle off so there are no time pressures on this job. I got the Brava/o adapter, ('A1' I think) with the new handle and rather nervously tried it for size on the lever. It fitted perfectly. :D Next I dug out the old handbrake gaiter and fitted it. The new handle came with 3 different sized grub screws, I found that the middle sized ones worked best, start them into the handle before fitting it. A little 'Fairy' on the adaptor and the handle just slid on. Tighten up the grub screws evenly so as not to get a twist on the handle. See Notorious's tip on this. Test the handbrake action a few times to see if it works ok. My handle was a close fit but not too tight. It lost some of the 'click' when applying the brake but still seems to engage fully. Good Luck :D Dont forget to post some pics. Mine are on my web site. This post has been created with the invaluable help of Notorious131, many thanks :D. Please feel free to comment, correct, criticise (constructive) or post any of your experiences below. Dave :)
| Re: Handbrake Handle Replacement Thanks for the guide. I have just installed my new MOMO carbon handbrake and a MOMO crystal gearknob.
__________________ http://www.fiatforum.com/members-mot...0-hlx-20v.html | |||
| | Coshstar | Stilo | 6 | 25-06-2004 14:28 |
| | SnowBord | Cinquecento / Seicento | 4 | 16-04-2004 01:15 |
| | brifletch | Stilo | 0 | 09-05-2003 03:08 |
| | Roberto | Bravo / Brava | 8 | 27-04-2003 21:08 |
| Handbrake handle | Geraint | Coupe | 0 | 29-04-2002 01:33 |
