The FIAT Forum
Go Back   The FIAT Forum > FIAT Cars > Marea > Marea > Styling
Old 12-04-2006   #1
BOGGY's Avatar
Trader Rating: (0)
Stereo settings lost when ignition switched off!
Hello all,
Just bought me a marea weekend 2.0 HLX, More than pleased with the car ,
but.....
put my own stereo in, JVC KD-G612 connected it with the two ISO plugs that were in the factory stereo. The stereo works fine but everytime i switch the ignition off i loose all the settings on my stereo, including time, equaliser settings and cd position.
This never happened with my last car and is getting a tad frustrating
so, has anybody experienced similar problems or know of any remedies, I haven't got a clue where to start.
many thanks!!!!
BOGGY is offline
Old 12-04-2006   #2
faster! FASTER!!!
Trader Rating: (2)
bulldog5046 has donated! United Kingdom
Re: Stereo settings lost when ignition switched off!
its a really easy one
switch the red and yellow wires around on the ISO block sorted
Ryan
The first UK Marea Turbo?
bulldog5046 is offline
Old 12-04-2006   #3
You can't fool owls.
Hellcat's Avatar
Trader Rating: (3)
Hellcat has donated! United Kingdom
Is it just me or have we had a spate of 'radio losing settings' threads recently? Start of April the time of year for fitting new head units?
Just out of interest what make of adapter did you use and where did you buy it from? I've heard the audioleads ones are a pretty poor fit and the plastic doesn't match in colour or texture.
Also have you kept your steering wheel buttons working?
'Not everything in black and white makes sense'
Hellcat is offline
Old 12-04-2006   #4
BOGGY's Avatar
Trader Rating: (0)
cheers for quick reply!
i found the red cable (12v power) but there is no yellow, do you know what position on the block it should be?
i used the audioleads adaptor from halfords, it's not a great fit. the bottom comes awy from the dash a bit, i may just glue it down.
BOGGY is offline
Old 12-04-2006   #5
Hellcat's Avatar
Trader Rating: (3)
I tried to find the manual on the JVC website but your model is not listed. Typical.
Do you have a pin-out in your manual? There should be memory and 12vdc inputs listed. Both need power to keep your settings and operate.
Put power only to memory will not allow the radio to switch on (But it will keep its settings ).
Put power only to 12vdc will allow the radio to switch on but it will lose its settings when switched off.
Put power to both will allow radio to operate and will keep settings but won't switch on and off with ignition.
Put power to memory and a switched power to 12vdc will allow the radio to switch on and off with ignition and keep settings.
Hellcat is offline
Old 12-04-2006   #6
BOGGY's Avatar
Trader Rating: (0)
seems i need to run a constant power conection from a live terminal (direct to battery) in the fusebox to the stereo. gonna have a crack tomorrow. thanks for all the help, i'll let you know if it works.
Rob
BOGGY is offline
Old 12-04-2006   #7
Hellcat's Avatar
Trader Rating: (3)
There should be a contstant 12v source available to the radio somewhere in there - otherwise the standard radio wouldn't be able to be switched on with the ignition off, or retain its settings.
Hellcat is offline
Old 12-04-2006   #8
faster! FASTER!!!
Trader Rating: (2)
i'll check it out for you tomorrow as i have loads of work to do on the marea so will let you know later in the day.
Ryan
Old 13-04-2006   #9
trumpeter's Avatar
Trader Rating: (0)
When i did mine the the 2 power leads with in line fuses (or were they bullet connectors?) coming out of the head unit, one red wire and i think the other was orange. Swap them over and it should work.
If not use a multimeter and check the pins with ignition off to find your 12v constant live.
Wires on the headunit are usually labeled with their function.
Trumpeter
'55 Stilo MultiWagon 1.9 JTD Dynamic
trumpeter is offline
Old 13-04-2006   #10
BOGGY's Avatar
Trader Rating: (0)
Problem solved!!!
red and orange wires swapped.
settings stored.
now i just need to find an adaptor to hook up the steering wheel controls and find a spot for me 6 - 9s.
thanks again everyone!!!!!!!!!!!!!
Rob
BOGGY is offline
vB code is On
Make your stereo turn on and off with the ignition Slippy Cinquecento / Seicento Guides 6 25-04-2008 20:52
ignition key lost for my 1974 - 124 spider ngombe1 Spider 1 31-05-2006 07:45
new stereo wont save settings? puntomk1 I.C.E 12 02-12-2005 11:06
connecting stereo to ignition stuartp Cinq/Sei > Technical 6 17-05-2004 20:46
