Thread Tools
Old 18-07-2017   #1
Keyfob swap
Does anyone know if it's easy/possible to change the key fob (as attached) to fiat 500 key fob? will the board and key fit?
Thanks.
motionlines is offline Reply With Quote Quote
Old 19-07-2017   #2
Re: Keyfob swap
by that i mean to change the current key fob shell which is pictured above to the one listed below:
Old 19-07-2017   #3
No strings on me
Eklipze3k's Avatar
Eklipze3k has donated!
Re: Keyfob swap
As far as I know, no, there's no way to swap the internals from one type to the other. The blade might fit, but the board/button's wouldn't line up.
Eklipze3k is offline Reply With Quote Quote
Old 19-07-2017   #4
Re: Keyfob swap
You might be able to reprogram a second hand one and have a new blade cut
Current car: 06 Fiat Stilo Sporting 150 Multijet
Past cars: 03 Stilo 1.2 Active 16v, 06 Focus 1.4 LS, 98 E36 323is, 97 Astra 1.6, 95 Astra 1.7 TDI, 95 Micra Super S, 96 Almera 1.6 GX, 94 Micra Super S, 97 Vectra 1.6 Envoy, 98 A4 1.8T Sport
dtimmins1985 is online now Reply With Quote Quote
Old 19-07-2017   #5
Re: Keyfob swap
thanks, though sounds more complicated then i thought it would be )
maybe at some point i'll order a shell from ali express and if it works fine - i'll update the thread.
Old 20-07-2017   #6
Re: Keyfob swap
Quote Originally Posted by motionlines View Post
It is not complicated at all
I did my own, my car didnt come with a fob, but i new it had the stuff inside the car to support one, they all left the factory with c/locking and remote antenna.
So i bought a 2nd key, re-cased it so its like brand new, programmed the remote fob using MES (registered version) and got my car security code from Sturgess Fiat for 12.50 + vat (15) to the forum.
Once programmed, i can unlock / lock / put the windows up and down with the remote, oh and open the boot.
Now i just need to get my blank blade cut.
I am sure the remotes use the same signal etc, i reckon its just the PCB and casing thats been re-designed.
Old 29-07-2017   #7
Re: Keyfob swap
Thread Tools
(T) Keyfob fitzy7375 Panda 7 07-12-2013 17:45
(G) How to swap internal components from keyfob Luca91 Grande Punto 0 01-09-2012 17:34
(G) Remote Keyfob Fiat1972 Panda 4 26-03-2012 22:09
(G) Keyfob TJetPete Bravo 37 07-06-2011 00:24
keyfob paul FIAT Boo Archives 4 19-02-2005 00:16
