The 1.0 turbo Fiesta comes with stop/start.
There has always been a recommendation with any turbo engine, to allow it to idle for 20-30 seconds before turning it off, to allow the turbo to slow down, so that wear/damage is minimised when the engine is turned off and the turbo oil supply stops.
With the Fiesta, the turbo engineer and the stop/start engineer weren't speaking to each other. Frequently, after a quick run, the stop/start will stop the engine immediately. This can't be good for the turbo. Moments later, the hot turbo, which is water cooled, will boil the coolant in it, causing spluttering into the expansion tank, like a kettle boiling. The coolant will of course circulate, but this continues for sometimes several minutes. This can't be good for the turbo either.
If you intend keeping the Fiesta for several years, put the money saved from fuel costs into a savings account for the inevitable new turbo. My school car is due to be replaced in 10 days time, just a year old and 21,000 miles. Good luck to its next owner.
