FIAT Auto Specialist Team
Thread Tools
Old 19-09-2005   #1
Air Recirculation
I keep seeing this mentioned in the specs and various reviews and stuff.
Is it just the option to use fresh air or cabin air as many cars have, or is it something special ?
TDF is offline Reply With Quote Quote
Old 19-09-2005   #2
Re: Air Recirculation
As you can probably guess, a normal ventilation system uses fresh air dragged in from the outside to cool/ heat the interior.
'Air recirculation' basically does what is say's on the tin. Rather than bringing in fresh air, it recirculates the air inside the car, for the following benefits:
  • It can heat the car up quicker in winter (the heater matrix is heating warmed air rather than cold air)
    If you have air conditioning it will cool the interior quicker
    If the atmopshere is polluted, i.e. you are following a smelly bus, you can stop the smells getting into the car
However, you should not use air recirculation for long periods of time because it increases the carbon monoxide levels in the car. This is because you breath Carbon Monoxide into the car, but the car keeps recirculating it.
Also, in the winter the lack of fresh air means that the windows will get moisture on the inside.
I don't use it for more than 5 minutes at a time
Big Northern Monkey
No longer a Fiat owner:
Audi A2 1.4TDI SE in silver with climate and rear bench seat. A beautiful car.
smart city-coupe Mk6 pure in Jack black with grey scordic trim. No mods (even the rubbish standard stereo)
JTD Monkey is offline Reply With Quote Quote
Old 19-09-2005   #3
Super LOL!
Stu DemonD's Avatar
Trader Rating: 1
Stu DemonD will never be forgotten
Stu DemonD has donated!
Jigsaw: Chess Pieces Champion
If you have proper CC in a car, it will control the recirculation for you - and open and close outside vents accordingly.
On the Stilo, it is called AQS - I presume Air Quality System.
See you next Tuesday
Stu DemonD is offline Reply With Quote Quote
Old 19-09-2005   #4
I guessed that was what it is, but is it just me or have Fiat made a big deal about it, as if it is something special.
I cant renember a car without this feature.
Old 25-09-2005   #5
I think I decided my car doesnt have aircon, thenI had a thumb through the manual and it describes a star marked button as 'manual climate control' and goes on to say it runs on r22.
So it does have aircon ? Wheres the condensor then, I couldn't see one, or a pump.
I guess the easiest thing is to switch it on and see if it gets cold, but I'm sat here naked, so it will have to wait.
Old 25-09-2005   #6
It the car has the button marked with a star that's described in the manual then you have A/C. What car do you have?
If you have never used it and you have had the car for a while then you are damaging the A/C. It needs to be used regulalry so that the compressor and valves etc. are kept lubricated, otherwise they will cease and cost the best part of 600 to overhaul!
Big Northern Monkey
Thread Tools
(T) Air Conditioning (climate system) controls ben743 Tipo (Classic) 8 04-03-2005 14:31
(G) Airbox on mk2 45 chrisunoman Uno 13 23-12-2004 01:15
(G) Hot air intake to air filter alexGS Uno 5 10-09-2004 11:59
(T) air box mod revisited jbackg Marea 1 18-08-2004 01:33
(G) Air Con buckster Stilo 9 11-08-2003 15:53
