Old 29-07-2005   #1
Portugal
All FIRE engine cam specs needed
As the title says, i'm looking for all the cam specs for the entire FIRE engine range to create a database. So far i've been able to acquire parts of specs but nothing complete so i thought the more knowlegeable members could give me a hand on this. This is to help people looking to upgrade their cams and i have no personal interest in it, just want to make my site into a complete FIRE engine information source which is proving to be a little difficult
Thanks in advance
smokeme is offline Reply With Quote Quote
Old 30-07-2005   #2
Abarth 500
Trader Rating: 1
EvilJaxx has donated!
Re: All FIRE engine cam specs needed
Hello,
The specification for the camshafts are as follows:
Punto/Seicento/Cinq 55:
Cube Capacity = 1108
Asp Valve Apertures = 7°-35°
Exhaust Valve Apertures = 37°-5°
Punto/Seicento/Cinq 60:
Cube Capacity = 1242
Punto MK1 75:
Asp Valve Apertures = 7°-41°
Exhaust Valve Apertures = 43°-5°
Punto 85 MK1 16v:
Asp Valve Apertures = -2°-42°
Exhaust Valve Apertures = 26°-6°
Punto 90 MK1:
Cube Capacity = 1581
Asp Valve Apertures = 6 °-46°
Exhaust Valve Apertures = 47°-7°
Punto GT MK1:
Cube Capacity = 1372
Asp Valve Apertures = 0°-43°
Exhaust Valve Apertures = 40°-3°
Punto TD60 MK1:
Cube Capacity = 1698
Asp Valve Apertures = 4°-32°
Exhaust Valve Apertures = 32°-4°
Punto TD70 MK1:
Tuning of Fiat Punto/Seicento/Cinq powered by engine 1108/1242 8-valves is possible with engine camshaft from Fiat Punto Mk1 75
Punto 60 Euro3 MK2:
Asp Valve Apertures = 2°-32°
Exhaust Valve Apertures = 30°-4°
Punto 80 Euro3 MK2:
Asp Valve Apertures = 0°-32°
Exhaust Valve Apertures = 32°-0°
EvilJaxx is offline Reply With Quote Quote
Old 30-07-2005   #3
Portugal
Thanks for the info but that was what i have so far, i'm looking for lift specs and the more obscure 769/999 cam data . Apreciate you trying though
This is what i have so far, as you can see it's not complete
http://smokeme.coconia.net/stock_part_specs.htm
Old 30-07-2005   #4
HP
Likes going topless.
HP's Avatar
HP has donated!
There's 1.7mm more lift on a Punto 75 cam than a 60/cinq one from what I've been able to measure. Can have a play to try and figure out how many mm lift that actually gives you, if you like.
Pete.
HP is offline Reply With Quote Quote
Old 31-07-2005   #5
Portugal
Thanks guys, really appreciate the effort.
Now on to check cfp , never read the stickies in the engine sections before
Old 01-08-2005   #6
Netherlands
With te Novitec cam I could almost see no difference of hight?
Angle is 276 degrees from Novitec
Don't Underestimate The Power Of TurboCinqy !!! About 160 BHP 230Nm Torque
TurboCinqy1250 is offline Reply With Quote Quote
Old 20-11-2012   #7
Portugal
Tuning of Fiat Uno powered by engine 999cc fire 8-valves is possible with engine camshaft from Fiat Punto Mk1 75?
Rui Gaspar is offline Reply With Quote Quote
Old 20-11-2012   #8
Trader Rating: 5
fingers99 has donated!
This is one old thread!
No idea which cam the 999cc engine uses. But the P75 cam is avaliable fairly cheaply -- well worth a go. All I can say for sure is that it will fit. You may be able to gain more by si8mply using a bigger throttle body -- assuming the 999 is fuel injection.
C & B might offer some advice if you can translate the request into Italian.
M12 fund £20
fingers99 is offline Reply With Quote Quote
Old 21-11-2012   #9
Portugal
It´s a Uno 45s 1992, no fuel injection, carburator. I want to make it faster but my buget it´s low. I race it the uno. The only limitation is the cc and no turbo. Just a litte faster and reving. Want can I do using parts from another fiat´s? Thank you. Sorry for my english.
Old 22-11-2012   #10
Trader Rating: 5
I'd try cam. If it's not restricted, there is a category for the 750 car club (big, prestigious clubman scene, often frequented by designers prior to and after their F1 career) which hosts a category using the 1108cc FIRE engines. See here. Somewhere on the Guy Croft site there are photos of one such engine -- with a single "split Weber" (they were popular on racing Minis) and a long, long, intake manifold.
Alternatively, if carb per cylinder is allowed, you might try bike carbs (as small as you can get -- 400cc, maybe).
M12 fund £20
Old 22-11-2012   #11
Portugal
Didn´t found anyting. What cam I do to make it faster? Standard 999cc, no turbo and standard carb whit a few mods? Thank you.
Old 22-11-2012   #12
Trader Rating: 5
Not sure what cam was originally fitted: you need to know that first -- the Uno secition might know.
Columbo and Boriani do lots of cams for the FIRE engines -- but they're not cheap.
I don't know the regulations for your races -- I think you'll need carb and cam, at least.
Some more here from the Guy Croft site.
M12 fund £20
Old 22-11-2012   #13
Portugal
Quote Originally Posted by Rui Gaspar View Post
yes but the 75 cam does not have the lobe to run the fuel pump which is mechanical on the carb engine.. can be done with a low pressure electric pump and using the mechanical pump minus the shaft as a regulator..
ganhas altas mas perdes baixas
(T) Seized engine - advice needed robertfry Punto (Mk2/2b) 13 28-11-2004 11:14
(T) My X1/9 twin cam conversion fiatfactory X1/9 2 19-08-2004 12:59
(G) 1600 DGT Cam specs Jononz Tipo 2 03-01-2004 16:34
(T) Cam Belt - Safe Engine Alan Birch Cinquecento / Seicento 13 16-05-2003 17:37
