colin james
- Feb 28, 2011
- 8
- 6
Hi all
I had to replace the clutch on my Panda Diesel after only 32000 miles!!!!
I have been driving for over 30 years and have NEVER worn a clutch out before.
Guess what? the clutch started slipping agian at 70000 miles, usually when giving it the beans in third gear.
I read somewhere that a garage had offered a repair on the hydraulic side to someone with a similar problem! So I tried to observe my driving technique with particular attention to the use of the clutch. I found that I hardly ever used the full travel of the clutch pedal to perform gear changes - I wondered if over time this could cause a lazy master cylinder or summat, so i made a conscious effort to put my foot all the wqay to the floor when changing gear - Anyway it worked!!!! its a couple of thousand miles since i started doing this and the clutch has not slipped again since (Im goin to regret saying that arnt I)
Any way i would like to read your comments on this theory
Col
Col
