Supposedly!Do the heaters/air con still work when the car auto switches off its engine?
It’s apparently such a common problem .
That if you have the aircon on or the heater turned up the “start stop” will not function correctly and show the “start stop unavailable” message.whats a problem? Majority of salesmen I know/met know nothing about stop/start anyway.
Another problem that a lot of people in the Evo section have encountered is that when you engage reverse the “start stop” will then not function either.
Sorry I didn’t explain that very well, the reverse issue is apparently: When “start stop” is engaged and you then reverse your car when you drive your car forward again the “start stop” function will no longer work.thats because due to certain parameters its not available.
why would you want stop/start in reverse?
I'm sure there is a list of times when stop/start will not function (for logical/safety reasons) in the handbook or on the fiat.com site. If not let me know & i'll look it out.
“Start Stop” is indeed a very good idea I can’t argue with that, my issue is simply with the constant & sudden unavailability of it. Maybe if I persevered more but I have just lost confidence in it, therefore I simply switch it off now as that’s easier, if however I forget to switch it off maybe coincidentally that’s when it plays up.I think the reverse issue was covered in the 500 section about this, cant remember the outcome so will have to look it up.
Stop/start is actually very good (if you stall the car just press clutch, no messing about with key etc) and although I dont have this feature I come across and use it almost daily.
I just wish you could set the damn thing to off by default.
at the moment it seems to be causing more hassle than good...
Have you come across it on the Evo? I have never looked at the 500 section for issues with “start stop” to be honest, I do know that out of the small number of Evo owners on the forum there seems to be a fair amount that have had issues with it, does the “Start Stop” system differ slightly on the Evo to other models?
I take it you work with Fiat then?!... just a shame that my local Fiat Dealership wasn’t as helpful or knowledgeable as yourself on the matter.Never had a stop/start issue with the Evo and one issue with it one the 500 which was quickly sorted (within minutes) however the customer came back straight away saying it wasn't working I went for test drive to show her how the system operates and when it does/does not operate and she was over the moon that it worked 100% and the fact someone actually spent time explaining the workings to her.
You can switch it off via the button on the dash, however it is set to on by default, so every time you restart the engine you have to remember to switch it off again.Can you not disengage it then?
My Hill Assist doesn't work when the stop start works. I'm constantly rolling backwards whilst I wait for the engine to start up.
As I have the duologic transmission I can't hold the break abs accelerate at the same time.
I hand my 500C serviced last week and they said that its normal.
Dangerous and costly if I roll into the car behind.
Generally you'd hold your foot on the brake put the clutch in and the engine will start up. Select the gear and as you bring your foot up on the clutch release the brake and give it a little gas. You should then pull nicely up the hill without rolling back and without the need for hill hold features, however in this instance the hill hold should still hold the car until you start moving forwards or for a few seconds.
If you roll back into the car behind this would be entirely your fault and nothing to do with any features of the car.
