95 m 1.1 punto red light stays on
scotty
Essex
hi my girlfriends got a punto 1.1 55sx 1995 m reg she's got all three key (1 red 2 blue) and when you go to start it it deosnt want to know the red light just stays on constantly someone looked at it and they said it could be (they did tell her what was called but she forgot) the black box under the steering colum the key code box or something like that any helped would be appretiated if it deosnt end up cost a fortune
Scotty
sorry you are right its the orange light that comes on with an orange key that says code
in the little user manual you got it should tell you how to re enter the keys starting with the red, try that first before you panic, sorry i cant remember exackly how off hand,
also there is a reciver ring around the key hole with a wire that plugs into a box near the fuse box(behind little shelf thing, drives side, 2 screws to remove) make sure its not come unpluged,
ok ill give that a try but it turns out she has only got 1 red and 1 blue will that still be ok???
no havnt tried jump lead yet will try it, cant find the key procedure all in there is the emergancy start up. and the lights do come on but very dim,elec windows work but the heater/fan dont work
tried jump leads and no go but it was triying to turn over alot more thow and tried the emergancy start and that didnt work either. but the emergancy in the handbook is done by the accelrator not with any keys - sequence
also i noticed that there seemed to be somthing missing on the drivers side engine bay, it might just be somthing that was there before but i dont know. its a rectangel plate about 10" long and a goldish colour i looked in the hand book it deosnt show anything but look on the net and i think it could be part of the egine ignition system? is the ignition system located on drives engine bay???? :bang:
yer it was the ecu missing but i spoke to the bloke who looked at it and he has still got it so im getting that back today ive charged the battery up last night so i will try when i get from work, hopefully i get it resolved. thanks for all your help so far (y)
got another problem still aint got it started yet but the red injector light is on what deos this mean and will i be able to start the engine with this on???
the light was on before he took thow, i think he tried to nick it personally but coz she a women she didnt no so , what sort of problems could it be? ive changed the battery over and its trying to turn over alot more but still no go.. its seems it aint getting enough power to give that last kick and it seems to die down even thow the battery is fully charged could it be the starter motor
