Re: FREE Fiat diagnostic software
no leads for 3 pin like mk1 puntos then? i see they are listed in the soft ware.
it has no punto mk2b listed, it has....
punto '03
punto INT
Is Punto mk2b the INT?
The Gendan package comes with all the leads you need to connect to the 16 pin OBD connector. It uses adaptor leads instead of switches on the connector.
With the registered version of FES, all future updates are free.
You can only use the registered version on one laptop. Installing it generates a hardware key from the laptop and the password Yani gives you only works with that hardware key. If you get a new laptop in the future, Yani will give you a new password for it.
punto '03
punto INT
