FREE to try Fiat diagnostic software
Re: FREE Fiat diagnostic software
Hello people.
My car is Fiat Pálio 1.5 year 1997 manufactured in Brazil , it has ECU Magneti Marelli IAW 1G7 , Fiatecuscan doesn´t works with my car , how to do ?
Thanks.
I will try that s/w with my Alfa Spider and see what happens.
Re Fiat diagnostic
Hi new member/ fiat stilo 1.2 02. model air/con replaced engine with 03 model which had no air/con so left own in, everthing working fine except engine warning fault comes on with ''engine fault' showing on dash after 5sec's goes out and dosen,t show anymore while driving does this everytime I start any Ideas nor do I have to spend money for test, as I say no oil nor water loss everything seems to be running OK and smooth
Cheers Kenny C
Will this work on bravo 1996.?
is this a good deal link removed because they get crap company to deliver who loose the stuff and driver signs it to say you recived it or does the lead still need modifying?
if i buy the paid version now are future updates free?
The Gendan package comes with all the leads you need to connect to the 16 pin OBD connector. It uses adaptor leads instead of switches on the connector.
With the registered version of FES, all future updates are free.
You can only use the registered version on one laptop. Installing it generates a hardware key from the laptop and the password Yani gives you only works with that hardware key. If you get a new laptop in the future, Yani will give you a new password for it.
As Davren has pointed out Gendan do both a complete kit or you can buy the "fiat" leads separately.
I have done the mods to KKL and ELM interfaces and also tested the Gendan cables with these devices. I've also be using Gendan kit for a long time and have never had any issues. They are not the cheapest on the block but well worth the money for hassle free kit.
One point of caution if you have a Fiat Croma. For some reason Fiat have put the power steering on Pin 12 and not the usual Pin 9. The Gendan cables I have do not cater for pin twelve as I was one of the first, if not the first person to get these cables having asked Gendan for a 'cable patch' solution ages ago.
I'm hoping the Fiat Croma is the ONLY odd ball Fiat in the Fiat fleet that uses Pin 12 for some functions.
i was hoping to get a Croma one day :(
From all the posts I see on the Fiat ECU Scan website and elsewhere the key to ELM interfaces is to get a genuine ELM interface and not a cheap generic interface claiming ELM x.x
There are so called Elm 1.5 units out there. There is no Elm 1.5! 1.4 is the latest. Anything over ths is hog wash.
Also some cheap Elm 1.x units appear to have incorrect bus termination components so sometmes connect, other times don't connect and other times just leave you in a completely confused state of mind and frustration.
I strongly suggest that anybody buying ELM based connection kit do a little research before actually purchasing.
Fiat uno 1100 (1990)
Can some one plz help me with the wiring on the ignition module
