D Dawny1970 New member Joined Sep 16, 2008 Messages 2 Points 2 Sep 16, 2008 #1 Hi can anyone tell me where the coolant is in a fiat punto 1.2 T reg please? My Daughter has a leak from somewhere but cant see where it is coming from. Thanks Dawn
jug blessed are the apostates Parked in the garage Joined Nov 28, 2005 Messages 27,935 Points 3,763 Location Durham Sep 16, 2008 #2 head gasket failure is very common on the 1.2. if its an "invisible leak" then it will most likely be that. you fill up the coolant using the filler cap on the side of the radiator.
