FIAT Auto Specialist Team
Thread Tools
Old 01-09-2008   #1
Doblo 1.3 multijet engine knock
Hi guys
I have purchased a new Doblo van with a 1.3 ltr 16 valve multijet engine.
I'm not sure about an engine knock or more a tapping sound on start up - sounds like a excessive cam follower clearance or the diesel knock you hear from the old black taxi cabs. I have noticed the noise after about 200 miles or more from new and only from cold, after it has warmed up it sounds like a modern diesel should. I have now done 6,000 miles and no change. Can someone please tell me if this is normal.
Thanks Wiz
Wiz is offline Reply With Quote Quote
Old 01-09-2008   #2
Re: Doblo 1.3 multijet engine knock
i work at fiat and were always getting things like this on 1.3, always from cold, once things warm up its fine, unless u rele think its gonna shake its bolts off i wouldnt worry about it
loves2spooge is offline Reply With Quote Quote
Old 02-09-2008   #3
OK Spooge thought that might be the case, thanks for the info.
Wiz.
Old 05-09-2008   #4
sludgeguts has donated!
Mine's got a bit of a squeek from cold but I sit there for a while, not revving, to allow the oil to circulate then everything's fine
Sick of the constant tax hikes?
See how much it costs you & write to your MP.
http://www.petrolprices.com/itsyourduty/
sludgeguts is offline Reply With Quote Quote
Thread Tools
(T) Doblo 1.3 multijet Blown engine orbiplaya Doblo 13 06-01-2008 18:45
(T) doblo 1.3 multijet flintstonesdog Doblo 5 25-11-2007 23:59
(T) 1.6 knock sensor problem [duff ECU?] stiloalex25 Stilo 10 23-07-2007 14:08
(T) Knock Knock Knocking near Right Hand door...... Freebeer Punto (Mk2/2b) 7 07-11-2006 14:35
