skydome
Hi all, I've had an intermittent fault on my 2004 PANDA. The OBD faoult code is U1601, the ABS and Power Steering warning indicators come on along with the MIL light and the Speedo and Tacho stop working.
I found an Italian site that listed a description for this code which was in Italian but translated said "Poor Wiring Conection". This obviously related to the CAN BUS as other listings refer to Can Bus Problem.
Yesterday the fault was would not go so I took out theinstrument pod and dis/reconected the plug. The fault was immediately gone and the car worked ok.
Is it likely that I have fixed the bad connection on the Can Bus A or B wires between the Body Computer and the Instrument Panel Node or has it just gone away again?
If you think this has fixed it then this may be of use to other members with similar problems. Regards ~ Skydome
