| hi im just wondering if any other punto owners have had problems with irratic revs? The are all over the place and idling higher than normal. this all started when it overheated ( i cooked it! ) because of a dodgy fan assembly. any ideas??
| | #2 | |||||
| Re: Revs
But if u've overheated it - could be worse? headgasket? Ziggy
| | #3 | ||
| Re: Revs ya sounds like the head gasket, check under the oil filler cap to see if there is white stuff there, or if the level of coolant has dropped and the oil has risen. those were the signs i was told to look out for in a gasket fault. it would be good to rule that out at least.
__________________ ![]() French Connection(s) to Italian Job | |||
| revs | mrcinquecento | Cinq/Sei > Technical | 9 | 10-05-2008 18:07 |
| revs | needspeed | Cinquecento / Seicento | 4 | 19-12-2007 19:48 |
| revs take a while to get down | greekguy | Bravo / Brava | 3 | 08-08-2006 11:25 |
| Up and down revs/extremely high revs!! | BURNER | Punto > Technical | 5 | 31-01-2005 19:39 |
| Help Revs | pokerface | Cinq/Sei > Technical | 0 | 21-03-2004 02:47 |
