| T-jet 120 into 150? The new Brava has a choice of 120 or 150 engines,does anyone know if there,s a simple way of making the T-jet punto into a 150 using the same part/parts from the 150 Brava,could it be a simple ECU change?
| Get Your Own Title! | Re: T-jet 120 into 150? Surely it's just different software, wouldn't even need to change the ECU? <--- Waits for someone that knows technical stuff to prove him wrong...
| | #3 | ||
| | #4 | ||
| | #5 | ||
| Re: T-jet 120 into 150? I've thought about this one too. Is it a simple re-map, or, if you change ECU is it easy to notice i.e. warranty work etc
__________________ ![]() | |||
| | #6 | ||
| The Thrill of Driving.... | Re: T-jet 120 into 150? The 150 T-jet has lower compression, so no its not just a "map" Car manufacturers now always develop cars correctly for long term durability, they can't afford there reputations to become tarnished by the ever increasing reliability we as the buying public demand, even cars now that are deemed to be unreliable would have been the epitome of reliability 20years ago. The compression ratio is lower, how they do this on this particular engine, I don't know, most likely different pistons, the 150 also has a bigger turbo as well. the reason for this is modern cars are mapped to give very flat torque curves, this makes them drivable and have none of the torque steer that used to be associated with turbo cars, therefore for a given amount of power a turbo is specified for that application, so the 120 turbo is very small, this helps spool up time and keeps good fuel economy. Hence why small turbo engines are becoming a vary favourable option for car manufactures, power outputs of bigger engines to drag about the lardy new cars, but with better fuel efficiency. It is likely that yes you could get some useful gains from remapping, but at what cost in terms of reliability is unknown yet, engines too new. You can take the VAG 1.8L 20V as an example it came in 150 and 180bhp guises with 9.6:1 compression ratio, but the higher output models the 210/225 etc were 8.6:1 and some other modifications like, stronger rods pistons and different turbo, yes you can remap the lower models higher but they will never last as well as the properly specified engines.
__________________ ![]() 1992 Lancia integrale EVO1; 1995 Toyota Celica GT4 ST205; 2001 Seicento Abarth 1.4 16V 6speed (OK that one's Emma's) Last edited by J333EVO; 16-03-2008 at 23:47. | ||
| | #7 | ||
| | #8 | |||||
| Get Your Own Title! | Re: T-jet 120 into 150? <--- Waits for someone that knows technical stuff to prove him wrong...
| | #9 | ||
| Re: T-jet 120 into 150? Thanks for the very useful tech reply,you really seem to know what you,re talking about,makes scense to me.
| what is the diffrence between t jet and multi jet? | salvo's yellow punto | Lets Talk FIAT | 8 | 22-03-2008 02:50 |
| | TroyO | Bravo | 12 | 10-03-2008 12:05 |
| | guyinbelfast | Grande Punto | 34 | 02-09-2007 10:56 |
| | lire100 | Grande Punto | 1 | 25-05-2007 00:49 |
| 1.9 JTD owners: do you have the 105 or the 120 model? | hendrik4dnet | Doblo | 27 | 08-10-2006 10:02 |
