Hi there, had to service mine last year. I decided to replace as much as possible with the kit and to clean it out as best i could with carb cleaner and the clever use of a vacuum cleaner and a straw!
I had lots of trouble with jets blocking so I really wanted to ensure that no bits of dirt were left in the tiny tubes that make up the webers innerds!! I think what was happening was that the old gasket that separated the top and bottom half was degrading and peices were occasionally falling into the float chamber.
Things I would recommend to do if you are doing it yourself are:
1) Check the floats for leaks (or even better replace it if the kit comes with it!) Can do this by holding it under water for a little while and observing any bubbles that rise.
2) Clean it out as thoroughly as you can as I was explaining earlier. But dont use anything that might contaminate the fuel or break up (like loo roll) as I found a bit of something I had used to clean mine out with had blocked a jet and was running so badly as it was one of the main accelerator jets!
3) Make sure you lay out the pieces carefully so you know which order they go back together again. So easy to put a jet back in the wrong place (well it was on mine as it was symetrical
4) I guess they all have needle valves? They wear out suprisingly easy I think. Definately a good idea to make sure that is replaced. In the kit that should come in a small plastic protecting case as it is very delicate and if scratched would I imagine make the car run very badly.
5) Infact, i think it would be best to remember in general to check every part you put back on (new or old) for any dirt / grit etc. I blow through the jets checking the individual holes for any signs of blockages aswell.
That is all I can think of for the moment, but doesnt mean there isnt more. It is late! They are fiddly to do, but I dont think its impossible. Service kits arent that expensive (when considering that new carbs can be hundreds). Entirely up to you really, dont do it alone though if you arent too certain as to what to do though would be my advice. I dont want to encourage you to risk wasting moneys!
I hope that helps, and good luck with it if you decide to go for it.
If I have said anything wrong aswell, please feel free to point it out!
Cheers,
Si
