The FIAT ForumThe FIAT Forum is in no way affiliated with or endorsed by FIAT S.p.A.
Forge Motorsport
Go Back   The FIAT Forum > General > Lets Talk FIAT
Old 04-05-2004   #1
Tripod
wolfracepunto's Avatar
wolfracepunto has donated!
so, there i was going to fit my new ecotek valve..
Thinking it would be the easiest job in the world, i started to fit the valve. "Cut the vacuum servo hose- coming from the brake servo" - it said. So i found this pipe coming from that area, and began to cut. Oh ****, wats this clear liqiud dripping out of the pipe? it smells of petrol...?? Yep i cut the bloody fuel pipe! And right after i'd cut the thing, I spotted the correct pipe to cut- typical.
Anyway i made a temp fix, but just found out it didnt really work so ive got no car for a week- its goin in on monday and im hoping it wont void the warranty...even tho i dont have the valve fitted
So, the lesson- get a haynes manual/ a person that knows or has done it b4, dont rush into it- have a good look round the engine bay 1st and that even the cleverest of people (ahem) make mistakes
EVERYONE- SPRAY YOUR PUNTOS BLACK
wolfracepunto is offline
Old 04-05-2004   #2
Forum moderator
Helz's Avatar
Trader Rating: 3
Helz is part of the official FF Events Team :)
Helz has donated!
Oooooooohhhhhhhhhh bad luck. Don't get too excited about the Haynes, the pictures of that area aren't exactly clear as I did consider PMing a copy to you when you asked which pipe it was but worse than useless really.
<font color="violet">
. o O Helz O o .
Proud owner of a silver Baby Brava with a Smiley air freshener
</font id="violet">
Helz is offline
Old 04-05-2004   #3
arc
this is where i stand
arc's Avatar
arc has donated!
what does the inlet manifold look like, yours is the 8v isnt it? If its anything like the inlet manifold on the older 1242cc 8v then there is no point fitting the ecotek on the brake servo pipe as it only feeds turblent air to one cylinder
Cinq Sporting - and yes, its broom yellow!
arc is offline
Old 04-05-2004   #4
haynes manual? check this.
http://www.fiatforum.com/forum/topic.asp?TOPIC_ID=10821
DOG is offline
Old 04-05-2004   #5
strange why it wont start then??? inertia/fuel cut off switch and has it been tripped, just a thaught it should be in the drivers side kick pannel near the accelerator peddle
1.6 elx 16v my baby
carman is offline
Old 04-05-2004   #6
Tripod
well a few ppl on here and elsewhere said it works well with the punto 8v mk 2 so it must be different...???
ive got a haynes on order lol
Old 04-05-2004   #7
Tripod
the car will start but im not riskin petrol sprayin everywhere due to the tube ive used in the bodge up.....it cant cope with the pressure and in the middle of the jubilee clips it forms a big bubble which probably will explode if i keep drivin it.....
Old 04-05-2004   #8
was ur punto at crail????
black punto
helybely_punto is offline
Old 04-05-2004   #9
Tripod
wats crail????
Old 04-05-2004   #10
its near st andrews in scotland big car event max p was there saw a mrk 2 with wolfrace accros side of his car that was all!!
black punto
Old 04-05-2004   #11
sorry to but in you have the lasses after you hehehe...
if you need info on fitting the echotec valve i have it on my database there is a vidio which explains the best way to set it up
http://uk.msnusers.com/autodatabase/modifications.msnw?action=get_message&mview=0&ID_M essage=220&LastModified=4675457654575582145
1.6 elx 16v my baby
carman is offline
Old 04-05-2004   #12
Tripod
lol cheers carman.....
hely_bely..??(lol) was it a sticker he had on?? wudnt mind one of them did it look good?
Old 04-05-2004   #13
The Negotiator has donated!
I know this is really obvious but whatever you do, do not drive it or run it! Your repair might be "ok" but sods law means that it will break and a small amount of spray will go onto your hot engine and there goes your car and in the worst case, you.
Again, sorry if this is a really obvious post and condesending but better safe than sorry right. Having done some work with sealing up pipes like this, I know you can so easily get a leak under any pressure and with something like petrol you can't risk it.
Paul
Uno 1.0ie Start. Standard.
I am a schizophrenic currently so please bear with me whilst I try to get rid of the 40+ personality.
The Negotiator is offline
Old 04-05-2004   #14
Tripod
its up the drive and stayin there until i take it to the garage nxt week.....they need to replace the whole fuel line apparently, not just the section in the engine which is gonna cost a bomb
Old 04-05-2004   #15
i will show you a pic u decide!!!!
black punto
(T) Wanna know where to fit ur ecotek valve? wolfracepunto Punto 10 02-07-2004 19:49
(T) how do i fit an ecotek valve to a punto 55 DC Punto 2 29-06-2004 20:59
(T) Ecotek valve syphon123 Cinquecento / Seicento 8 22-07-2003 20:28
(T) Ecotek Valve , Which hose does it fit to? Stumpy Punto 5 15-07-2003 00:33
Copyright ©2002 - 2010 FIAT Forum
