| Bravo 155 HGT | Alloy Question Ok so anyone know the rough weight of 1 Bravo HGT 15" alloy with a 195/55/15 tyre on it, only got damm fancy scales at home and wont weight the thing properly or me and the alloy as wont give a steady reading.. ie anywhere between 10 and 25Kg! Which i dont beleive! So if someone could help me out that'd be great just a rough reading of a similar sized alloy. Cheers
__________________ Loosening Dirt, Degreaser, Film Remover? What to use? Unusual CODE Problem - Bravo HGT ![]() Drives: Bravo HGT 155 Nov 2000 - Vroom Yellow ![]() ![]() | ||
| | #3 | ||
| Forum moderator | Re: Alloy Question Sorry, from my various selection of wheels, I don't have one of those to weigh ![]()
__________________ | ||
| | #4 | ||
| Bravo 155 HGT | Re: Alloy Question mmmm... think i'm gona need to buy some cheap scales that will do the job..
| | #5 | ||
| Forum moderator | Re: Alloy Question I think mine were about £3 from Asda!
| | #6 | ||
| :) | Re: Alloy Question Use a plank on a pivot, in the middle. Put the wheel on one end, the exact distance away from a pivot as a large bucket on the other. Measure out 1 litre amounts and pour into the bucket. Wait until the bucklet lifts the wheel off the ground and voila, accurate to around 1 kg. Of course each litre = 1 kg.
__________________ Now drives: '52 Megane 1.9dCi ![]() Past: Y-reg Fiat Brava JTD (Pale Blue) (2006) M-reg UNO (2003-2004) '51 Fiat Brava 80 SX (black) (2006) | ||
| | #7 | ||
| Forum moderator | Re: Alloy Question It would be easier just to spend £3 on some scales ![]()
| | #8 | ||
| | #9 | ||
| | #10 | ||
| ow! pinched my eyeball! | Re: Alloy Question like your thinking paul. always good to keep old school thinking in place. never know when you may need some lateral thinking in life
__________________ removed so the flufftards can dry their eyes ![]() Want +20BHP for £2? do not click this link!!!! | ||
| | #11 | ||
| :) | Re: Alloy Question Sometimes it's all you have and it's always useful to go back to basics.
| | #12 | ||
| | #13 | |||
| blessed are the apostates | Re: Alloy Question
but does it mean you're an engineer? ![]()
__________________ ![]() | |||
| | #14 | ||
| :) | Re: Alloy Question Well I am by job role, so it's it irrelevant if doing that would make me an engineer ![]()
| | #15 | ||
| Bravo 155 HGT | Re: Alloy Question OK so alloy +tyre weighs in at 15.3Kg not including packaging... which means say 65Kg courier needed for 4 packages. Anyone know of any cheap ones?
| Alloy Wheels Bolts | dark_knight | Punto > Technical | 5 | 14-04-2006 12:30 |
| Will an alloy of et49 fit a cinq? | CaneyJ | Cinq/Sei > Technical | 8 | 03-09-2005 06:56 |
| Sei Alloy Question! | MintySport | Cinquecento / Seicento | 2 | 24-04-2005 15:39 |
| 74 Spider carb question???? and drive shaft question | dicast1969 | Spider | 1 | 16-04-2005 08:19 |
| alloy question | cinquecento_sunderland | Cinq/Sei > Technical | 5 | 23-03-2005 22:40 |
